chrisrobbins1970 82 Posted February 10, 2020 Posted February 10, 2020 add three movies.. emby is not auto scrapping; getting metadata.. i have tried manually still getting no results.. can IMDB be added to the movie metadata downloader???
cnwinger 8 Posted February 10, 2020 Posted February 10, 2020 (edited) I'm also getting no search results when identifying a Music artist by entering a Musicbrainz or AudioDB Artist ID. Possibly related since both issues are blank search results? If not, I'll start a separate topic. Edited February 10, 2020 by cnwinger
Luke 42216 Posted February 10, 2020 Posted February 10, 2020 What internet metadata providers are enabled on your movie library? When you searched using Identify, what did you enter?
chrisrobbins1970 82 Posted February 10, 2020 Author Posted February 10, 2020 for example... Identity 2003 .. ive used the spelling..no results..ive used the imdb id: tt0309698.. no results.. see screenshots...
chrisrobbins1970 82 Posted February 10, 2020 Author Posted February 10, 2020 screenshot shows: the open movie database themoviedb
Luke 42216 Posted February 10, 2020 Posted February 10, 2020 Please attach the emby server log. thanks.
Luke 42216 Posted February 10, 2020 Posted February 10, 2020 Ok I see you did a search at 09:01. What did you enter into the Identify dialog?
chrisrobbins1970 82 Posted February 10, 2020 Author Posted February 10, 2020 identity > search .. no results
chrisrobbins1970 82 Posted February 10, 2020 Author Posted February 10, 2020 did a test with tv series... i am able to add new tv series and it scrapping with no issues.. seems to only not work with movies can IMDB be added to the emby server ??
Luke 42216 Posted February 10, 2020 Posted February 10, 2020 identity > search .. no results What did you enter ?
chrisrobbins1970 82 Posted February 10, 2020 Author Posted February 10, 2020 clicked on identify > put in identity > click search > no results shown
chrisrobbins1970 82 Posted February 10, 2020 Author Posted February 10, 2020 i guess there is no solution???
Luke 42216 Posted February 11, 2020 Posted February 11, 2020 clicked on identify > put in identity > click search > no results shown What exactly did you enter into the Identify dialog?
Luke 42216 Posted February 11, 2020 Posted February 11, 2020 i guess there is no solution??? Can you show a screenshot of the settings for your movie library? Thanks.
