Netbug 26 Posted January 23, 2021 Posted January 23, 2021 Apologies for the delay. Problem reproduced with "Spectre". Logs attached. ffmpeg-remux-42cb89d4-1a7b-4657-8ef5-9b002fd4018f_1.txt embyserver.txt
Luke 42243 Posted January 24, 2021 Posted January 24, 2021 22 hours ago, Netbug said: Apologies for the delay. Problem reproduced with "Spectre". Logs attached. ffmpeg-remux-42cb89d4-1a7b-4657-8ef5-9b002fd4018f_1.txt 51.85 kB · 0 downloads embyserver.txt 592.17 kB · 0 downloads In server transcoding settings try unchecking the option to allow subtitle extraction on the fly as it's just not quick enough in your environment. This will result in more server transcoding to burn the subtitles into the video, which you may not like either depending on the performance of your server machine. So for best results try using external .srt subtitles.
Blob 7 Posted January 31, 2021 Posted January 31, 2021 Hi, Just an suggestion and don't hate me for it. Does clearing up the subtitle cache folder on the server help? You have a Playstation on the photo of you AV setup, and with the current setup in my inviroment the PS playback is corrupting the cached subtitle file to 1kb in size for that media title. Playing that from chromecast will display no subtitle. Best regards.
Netbug 26 Posted January 31, 2021 Posted January 31, 2021 6 hours ago, Blob said: Hi, Just an suggestion and don't hate me for it. Does clearing up the subtitle cache folder on the server help? You have a Playstation on the photo of you AV setup, and with the current setup in my inviroment the PS playback is corrupting the cached subtitle file to 1kb in size for that media title. Playing that from chromecast will display no subtitle. Appreciate the thought. I almost never use the PS (for anything, really). But I'd like to know where the cache is located to clear it? Is it done through the interface or do I need to dig into the folder structure? Thanks.
Blob 7 Posted January 31, 2021 Posted January 31, 2021 6 minutes ago, Netbug said: Appreciate the thought. I almost never use the PS (for anything, really). But I'd like to know where the cache is located to clear it? Is it done through the interface or do I need to dig into the folder structure? Thanks. OK, Then probrally not related then. Content, Folders deleted within %userprofile%\appdata\roaming\emby-server\cache\subtitles. This removed the problematic 1kb cached subtitles created by another user's PS. 1
Luke 42243 Posted January 31, 2021 Posted January 31, 2021 3 hours ago, Blob said: OK, Then probrally not related then. Content, Folders deleted within %userprofile%\appdata\roaming\emby-server\cache\subtitles. This removed the problematic 1kb cached subtitles created by another user's PS. This has been corrected for the next release and won't happen anymore. Thanks. 1
Netbug 26 Posted May 25, 2021 Posted May 25, 2021 This problem seems to have come back from the dead. This week I have been unable to get subs working on anything that is streamed to the Chromecast. The following are the media i have tested so far: Highlander (1986) Mare of Easttown S01E01 Mythic Quest S02E04 Last Week Tonight S08E13 All of the above are in MKV containers. I am attaching logs. This started about 3 or 4 days ago. All of the above subtitles work on the mobile device itself (Samsung Galaxy S9) and when playing through the web interface on Chrome. embyserver3.txt embyserver2.txt embyserver.txt
Luke 42243 Posted May 25, 2021 Posted May 25, 2021 1 hour ago, Netbug said: This problem seems to have come back from the dead. This week I have been unable to get subs working on anything that is streamed to the Chromecast. The following are the media i have tested so far: Highlander (1986) Mare of Easttown S01E01 Mythic Quest S02E04 Last Week Tonight S08E13 All of the above are in MKV containers. I am attaching logs. This started about 3 or 4 days ago. All of the above subtitles work on the mobile device itself (Samsung Galaxy S9) and when playing through the web interface on Chrome. embyserver3.txt 2.42 MB · 0 downloads embyserver2.txt 1.95 MB · 0 downloads embyserver.txt 895.61 kB · 0 downloads HI, there's multiple log files here. what date and time did the problem occur?
Netbug 26 Posted May 25, 2021 Posted May 25, 2021 On 1/14/2021 at 2:45 PM, Luke said: Simply reproduce the problem again, then attach all log files that were modified during that timeframe. Thanks. Sorry, always get confused with log files. Most recent was with Mare of Easttown I would guess around 2000est today.
Netbug 26 Posted May 25, 2021 Posted May 25, 2021 14 hours ago, Luke said: HI, there's multiple log files here. what date and time did the problem occur? Do you need me to create new log files after a fresh reboot? I can if that would help.
Luke 42243 Posted May 25, 2021 Posted May 25, 2021 Just now, Netbug said: Do you need me to create new log files after a fresh reboot? I can if that would help. That would be great, thanks.
Netbug 26 Posted May 25, 2021 Posted May 25, 2021 (edited) Fresh boot of both Emby and the Chromecast. Attempted to play Mare of Easttown with subtitles around 1354 eastern time. Also tested The Good Doctor S04E18 at 1407 eastern time. Both were MKV containers. embyserver.txt Edited May 25, 2021 by Netbug
Luke 42243 Posted May 25, 2021 Posted May 25, 2021 1 minute ago, Netbug said: Fresh boot of both Emby and the Chromecast. Attempted to play Mare of Easttown with subtitles around 1354 eastern time. embyserver.txt 230.83 kB · 0 downloads Can you attach the ffmpeg log as well? Thanks.
Netbug 26 Posted May 25, 2021 Posted May 25, 2021 There are a lot for that time period. I'm currently watching The Good Doctor and there are no subs, so that is likely the most recent one. ffmpeg-transcode-8bb7cd20-d3b5-46f1-b5d6-0d35bb162c04_1.txt ffmpeg-transcode-11f9b5fd-a2fe-42fc-8d11-bb6eb23b888c_1.txt ffmpeg-transcode-8486c205-222c-4537-ad25-5628bc8a80ff_1.txt ffmpeg-transcode-e2bcf326-25e7-4edd-b977-ad78c3d5e1f2_1.txt ffmpeg-transcode-e8c08536-a76a-464c-a5bd-bd5f9a9dc135_1.txt ffmpeg-remux-0782e03c-9fab-4724-bcab-ad6339909b88_1.txt ffmpeg-transcode-6d1a52c1-b6f6-4d6b-b3fd-faa21706f2d4_1.txt
Netbug 26 Posted May 25, 2021 Posted May 25, 2021 Am I doing something wrong or is there something odd going on? Are those the correct files that you need?
Netbug 26 Posted May 27, 2021 Posted May 27, 2021 I also just tested on my second Chromecast (which I should have done before). It also is unable to display subtitles for the above mentioned programs. Log attached. Viewing time was about 1150 eastern time. I'm not sure if it's important, but when i turned on the second Chromecast (I don't use it much), there was an update which executed. Possibly a change causing problems? embyserver.txt ffmpeg-transcode-49a5c039-50ba-4f97-8744-cb5d3455df1b_1.txt
Netbug 26 Posted May 27, 2021 Posted May 27, 2021 1 minute ago, Luke said: How does the web app compare? Sorry, how do you mean? Like try to run it through Chrome on the phone and stream from there to the Chromecast?
Netbug 26 Posted May 27, 2021 Posted May 27, 2021 Just now, Luke said: I mean just playing in the web app Sorry, Luke. I don't mean to be ignorant, but Chromecasts don't have a browser as far as I'm aware. If you're asking if it works when playing through the webapp on my computer (at https://emby.media) the subtitles work fine.
Netbug 26 Posted May 30, 2021 Posted May 30, 2021 Quick update: separately downloaded SRT subtitles seem to work all right. One thing of note, is has been taking longer and longer for MKV movies to load to Chromecast. I'm not sure if that's related, but for example, a 17GB 1080P Justice League Snyder Cut takes between 5 and 7 minutes to load on the Chromecast. Did you find anything of use from the logs I submitted?
Netbug 26 Posted June 6, 2021 Posted June 6, 2021 Just a quick follow-up to this; I don't know what the userbase size if for Chromecast, but for the past few releases I have had a lot of trouble with Chromecast from the android app. Along with the above mentioned subtitle issue, there are also extreme playback stutters and freezing. I've tested this on both a Chromecast Ultra and a Chromecast and the same issues are on both. When I play direct from my LG TV app, it works fine. All other devices and direct playback work fine. Just Chromecast integration.
Luke 42243 Posted June 6, 2021 Posted June 6, 2021 Stuttering is usually a matter of the bitrate being too high for the connection and can be easily solved by lowering the chromecast quality setting.
