Reverse Proxy Won't Start
Go to solution Solved by pwhodges,
tomnjerry74
Huge thank you to Paul @@pwhodges for taking the time to help me figure this out!
Like he said, if anyone is having trouble please make sure to check that you do not have any entries in your router pointing 80 and 443 ports to Emby ports.
I'd also like to mention the solution to my first problem, which was Caddy not being able to start due to port 80 already being used.
  1. On Windows 10, navigate to the start menu and type 'services.msc'.
  2. This should open up a list of all of your system's services. Look for 'ISS Admin Service' as well as 'World Wide Web Publishing Service'.
  3. Right click on both of these services, stop, and then disable them.
  4. Port 80 should be free (as long as you don't have other programs using it) and Caddy will be able to start up successfully.
