serverebps01 12 Posted February 7, 2020 Posted February 7, 2020 I am an android tv user in my mi box s the forward function is not working every time i try to advance, the movie or series goes back to the beginning, there is some more with this problem on android tv
Luke 42246 Posted February 7, 2020 Posted February 7, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks !
MembyR 0 Posted February 7, 2020 Posted February 7, 2020 (edited) Android TV app v. 1.7.78 but also LG web OS app (up to date as of 7 february 2020) Describe the problem in your own words, including what you're trying to accomplish, and where you're getting stuck. Trying to fast forward or backward on certain videofile does not work. It brings you back to the beginning of the film. Tested this on a range of videofiles, SD, HD, 4K. Only some of my 4K files do not fast forward/backward. I added the file specifics below, don't know if that helps. Video Title4K HEVC CodecHEVC ProfileMain 10 Level153 Resolution3840x2160 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate23.976 Bitrate62,615 kbps Video rangeHDR Color primariesbt2020 Color spacebt2020nc Color transfersmpte2084 Pixel formatyuv420p10le Ref frames1 Audio TitleEnglish DTS 5.1 (Default) LanguageEnglish CodecDTS ProfileDTS-HD MA Layout5.1 Channels6 ch Sample rate48,000 Hz Bit depth24 bit DefaultYes If you saw error messages, please tell us what they were. If the problem is difficult to explain, please include screenshots that demonstrate the issue. No error messages were shown Include the version of the server that you're using. This information can be found on the front page of the server's web dashboard. 4.3.1.0 Some apps have their own logs (see EMC and Android TV section below). For others, they may send logs to us automatically if there is a crash. Please tell us as much about the scenario as you can to help us locate them. I tried sending it on my Shield, but saw no option to send a log on my screen after enabling debugging... (also; the input for passwords and IP server adresses can only be done using the app on my phone, the remote won't go to 'cancel' or 'OK', but that's another thing. here's the log from my server, after rotating it and trying to skip forward a few times: 2020-02-08 00:00:55.337 Info App: Application version: 4.3.1.0 2020-02-08 00:00:55.338 Info App: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.76 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Program data path: /var/lib/emby Application directory: /opt/emby-server/system 2020-02-08 00:00:55.338 Info App: Plugins: Auto Box Sets 1.2.3.0 Bluray Folder Support 1.0.0.0 Cinema Intros 1.0.30.0 Dlna 1.0.33.0 Dvd Folder Support 1.0.0.0 Fanart.tv 1.0.5.0 Last.fm 1.0.21.0 MovieDb 1.2.9.0 MusicBrainz 1.0.11.0 Nfo Metadata 1.0.24.0 OMDb 1.0.8.0 Open Subtitles 1.0.22.0 Port Mapper 1.0.2.0 Studio Images 1.0.1.0 TheAudioDb 1.0.6.0 TheTVDB 1.0.28.0 Trakt 3.4.3.0 TuneIn 1.2.2.0 Webhooks 1.0.9.0 2020-02-08 00:00:55.338 Info TaskManager: Rotate log file Completed after 0 minute(s) and 0 seconds 2020-02-08 00:00:55.641 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:56.109 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:56.492 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:56.872 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:57.289 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36 2020-02-08 00:00:57.292 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36 2020-02-08 00:00:57.294 Info HttpServer: HTTP Response 200 to 192.168.1.18. Time: 1ms. http://192.168.1.6:8096/emby/System/Configuration 2020-02-08 00:00:57.296 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:57.392 Info HttpServer: HTTP Response 200 to 192.168.1.18. Time: 104ms. http://192.168.1.6:8096/emby/System/Logs 2020-02-08 00:00:57.747 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:58.228 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:58.620 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:59.031 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:59.424 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:00:59.736 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:00.201 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:00.749 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:01.063 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:01.459 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:02.440 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:03.051 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:04.071 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:04.865 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:05.544 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:05.836 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:06.384 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:06.997 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:07.010 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 13ms. http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253?format=json 2020-02-08 00:01:07.068 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:07.074 Info HttpServer: HTTP POST http://192.168.1.6:8096/emby/Items/309253/PlaybackInfo?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:07.082 Info App: User policy for bram. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-02-08 00:01:07.082 Info App: User policy for bram. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-02-08 00:01:07.083 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 10ms. http://192.168.1.6:8096/emby/Items/309253/PlaybackInfo?format=json 2020-02-08 00:01:07.100 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253/SpecialFeatures?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:07.102 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 2ms. http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253/SpecialFeatures?format=json 2020-02-08 00:01:07.108 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items?ImageTypeLimit=1&recursive=true&IncludeItemTypes=BoxSet%2CPlaylist&ListItemIds=309253&StartIndex=0&Fields=PrimaryImageAspectRatio%2CSortName%2COverview%2CCanDelete%2CItemCounts%2CDisplayPreferencesId%2CCriticRating%2CCommunityRating%2COfficialRating%2CPremiereDate%2CEndDate%2CProductionYear&Limit=50&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:07.109 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Items/309253/Similar?Fields=PrimaryImageAspectRatio&UserId=37e574b64beb4a489d33fda782ad4f9b&Limit=10&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:07.110 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Items/309253/Images/Backdrop/1?Accept=webp&MaxWidth=1200&EnableImageEnhancers=true&Tag=8c50ae5788fdc3e7f7f119fc595e9fc1. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:07.118 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253/LocalTrailers?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:07.371 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:07.403 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 296ms. http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items?ImageTypeLimit=1&recursive=true&IncludeItemTypes=BoxSet%2CPlaylist&ListItemIds=309253&StartIndex=0&Fields=PrimaryImageAspectRatio%2CSortName%2COverview%2CCanDelete%2CItemCounts%2CDisplayPreferencesId%2CCriticRating%2CCommunityRating%2COfficialRating%2CPremiereDate%2CEndDate%2CProductionYear&Limit=50&format=json 2020-02-08 00:01:07.405 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 295ms. http://192.168.1.6:8096/emby/Items/309253/Images/Backdrop/1?Accept=webp&MaxWidth=1200&EnableImageEnhancers=true&Tag=8c50ae5788fdc3e7f7f119fc595e9fc1 2020-02-08 00:01:07.416 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 304ms. http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253/LocalTrailers?format=json 2020-02-08 00:01:07.416 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 307ms. http://192.168.1.6:8096/emby/Items/309253/Similar?Fields=PrimaryImageAspectRatio&UserId=37e574b64beb4a489d33fda782ad4f9b&Limit=10&format=json 2020-02-08 00:01:08.121 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:08.366 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253/Intros?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:08.369 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 4ms. http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253/Intros?format=json 2020-02-08 00:01:08.470 Info HttpServer: HTTP POST http://192.168.1.6:8096/emby/Items/309253/PlaybackInfo?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:08.481 Info App: User policy for bram. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-02-08 00:01:08.483 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 13ms. http://192.168.1.6:8096/emby/Items/309253/PlaybackInfo?format=json 2020-02-08 00:01:08.559 Info HttpServer: HTTP POST http://192.168.1.6:8096/emby/Sessions/Playing. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:08.565 Info SessionManager: Playback start reported by app AndroidTv 1.7.78g playing Predators. Started at 0 ms 2020-02-08 00:01:08.566 Info Trakt: Playback Started 2020-02-08 00:01:08.566 Info HttpServer: HTTP Response 204 to 192.168.1.22. Time: 7ms. http://192.168.1.6:8096/emby/Sessions/Playing 2020-02-08 00:01:08.566 Info HttpClient: POST https://api.trakt.tv/scrobble/start 2020-02-08 00:01:08.621 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:08.962 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:09.453 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:09.787 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:10.171 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:10.471 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:10.819 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:11.216 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:11.707 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:12.204 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:12.772 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:13.240 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:13.519 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809. User-Agent=Emby/1.7.78g (Linux;Android 9) ExoPlayerLib/2.10.6, Accept-Encoding=identity, Icy-MetaData=1, Host=192.168.1.6:8096, Connection=Keep-Alive 2020-02-08 00:01:13.527 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Items/309253/ThumbnailSet?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:13.532 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 5ms. http://192.168.1.6:8096/emby/Items/309253/ThumbnailSet?format=json 2020-02-08 00:01:13.643 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:13.762 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/DisplayPreferences/309253?client=ATV&userId=37e574b64beb4a489d33fda782ad4f9b&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:13.764 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 2ms. http://192.168.1.6:8096/emby/DisplayPreferences/309253?client=ATV&userId=37e574b64beb4a489d33fda782ad4f9b&format=json 2020-02-08 00:01:14.046 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:14.554 Info HttpServer: HTTP POST http://192.168.1.6:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:14.556 Info HttpServer: HTTP Response 204 to 192.168.1.22. Time: 3ms. http://192.168.1.6:8096/emby/Sessions/Playing/Progress 2020-02-08 00:01:14.667 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:14.991 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:15.328 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:15.695 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:16.047 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:17.434 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:17.848 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:18.287 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:18.795 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:19.192 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:19.543 Info HttpServer: SocketException: http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809&api_key=8224eea463dd4a1dba4b05b4a5ed6a3a 2020-02-08 00:01:19.543 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 6024ms. http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809 2020-02-08 00:01:19.544 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809. User-Agent=Emby/1.7.78g (Linux;Android 9) ExoPlayerLib/2.10.6, Accept-Encoding=identity, Icy-MetaData=1, Host=192.168.1.6:8096, Connection=Keep-Alive 2020-02-08 00:01:19.760 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:20.216 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:20.596 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:20.959 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:21.367 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:21.670 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:22.010 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:22.377 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:22.736 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:23.176 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:23.552 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:23.908 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:24.235 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:24.522 Info HttpServer: HTTP POST http://192.168.1.6:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:24.524 Info HttpServer: HTTP Response 204 to 192.168.1.22. Time: 2ms. http://192.168.1.6:8096/emby/Sessions/Playing/Progress 2020-02-08 00:01:24.594 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:24.897 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:25.254 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:25.583 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:25.918 Info HttpServer: SocketException: http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809&api_key=8224eea463dd4a1dba4b05b4a5ed6a3a 2020-02-08 00:01:25.918 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 6375ms. http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809 2020-02-08 00:01:25.920 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809. User-Agent=Emby/1.7.78g (Linux;Android 9) ExoPlayerLib/2.10.6, Accept-Encoding=identity, Icy-MetaData=1, Host=192.168.1.6:8096, Connection=Keep-Alive 2020-02-08 00:01:25.928 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:26.311 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:26.648 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:26.993 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:27.423 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:27.850 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:28.278 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:28.754 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:29.204 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:29.530 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:30.014 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:30.391 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:30.797 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:31.275 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:31.785 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:32.268 Info HttpServer: SocketException: http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809&api_key=8224eea463dd4a1dba4b05b4a5ed6a3a 2020-02-08 00:01:32.268 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 6348ms. http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809 2020-02-08 00:01:32.272 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809. User-Agent=Emby/1.7.78g (Linux;Android 9) ExoPlayerLib/2.10.6, Accept-Encoding=identity, Icy-MetaData=1, Host=192.168.1.6:8096, Connection=Keep-Alive 2020-02-08 00:01:32.388 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:32.992 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:33.367 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:33.796 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:34.101 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:34.454 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:34.563 Info HttpServer: HTTP POST http://192.168.1.6:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:34.568 Info HttpServer: HTTP Response 204 to 192.168.1.22. Time: 5ms. http://192.168.1.6:8096/emby/Sessions/Playing/Progress 2020-02-08 00:01:34.856 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:35.207 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:35.535 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:35.843 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:36.162 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:36.543 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:36.992 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:37.604 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:38.199 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:38.756 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:39.296 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:39.724 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:40.051 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:40.407 Info HttpServer: SocketException: http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809&api_key=8224eea463dd4a1dba4b05b4a5ed6a3a 2020-02-08 00:01:40.407 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 8135ms. http://192.168.1.6:8096/emby/videos/309253/stream.mkv?DeviceId=88bf9613ff065520&MediaSourceId=308d7e082d8a76e109b64282bd08bb67&Static=true&PlaySessionId=333803eb83f045f8a9f5cf03c087d809 2020-02-08 00:01:40.418 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:40.429 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 10ms. http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253?format=json 2020-02-08 00:01:40.447 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Items/309253/Similar?Fields=Overview%2CPrimaryImageAspectRatio&UserId=37e574b64beb4a489d33fda782ad4f9b&Limit=1&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:40.455 Info HttpServer: HTTP POST http://192.168.1.6:8096/emby/Sessions/Playing/Stopped. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:40.456 Info SessionManager: Playback stopped reported by app AndroidTv 1.7.78g playing Predators. Stopped at 7362 ms 2020-02-08 00:01:40.458 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 11ms. http://192.168.1.6:8096/emby/Items/309253/Similar?Fields=Overview%2CPrimaryImageAspectRatio&UserId=37e574b64beb4a489d33fda782ad4f9b&Limit=1&format=json 2020-02-08 00:01:40.459 Info Trakt: Playback Stopped 2020-02-08 00:01:40.459 Info Trakt: Item Not fully played. Tell trakt.tv we are no longer watching but don't scrobble 2020-02-08 00:01:40.461 Info HttpServer: HTTP Response 204 to 192.168.1.22. Time: 4ms. http://192.168.1.6:8096/emby/Sessions/Playing/Stopped 2020-02-08 00:01:40.462 Info HttpClient: POST https://api.trakt.tv/scrobble/pause 2020-02-08 00:01:40.613 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:40.881 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-02-08 00:01:40.891 Info HttpServer: HTTP Response 200 to 192.168.1.22. Time: 10ms. http://192.168.1.6:8096/emby/Users/37e574b64beb4a489d33fda782ad4f9b/Items/309253?format=json 2020-02-08 00:01:41.130 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:41.575 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:41.910 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:42.262 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:42.575 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:42.970 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:43.293 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:43.731 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:44.267 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:44.792 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:45.315 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:45.691 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:46.071 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:46.395 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:46.761 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:47.080 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:47.419 Info HttpClient: POST https://vip-api.opensubtitles.org/xml-rpc 2020-02-08 00:01:47.546 Info HttpServer: HTTP GET http://192.168.1.6:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36 Edited February 7, 2020 by MembyR
ebr 16338 Posted February 8, 2020 Posted February 8, 2020 Hi. Try refreshing metadata on the video. 1
MembyR 0 Posted February 8, 2020 Posted February 8, 2020 Hi. Try refreshing metadata on the video. Thnx, tried it, but still not working
ebr 16338 Posted February 8, 2020 Posted February 8, 2020 What kind of container is this file? Something is making it unseekable.
ebr 16338 Posted February 9, 2020 Posted February 9, 2020 Can you try remuxing it? Most times, something like this is a bad index or other corrupt part of the file.
Luke 42246 Posted February 9, 2020 Posted February 9, 2020 Our media conversion feature can help with this.
Cthalpa 11 Posted February 9, 2020 Posted February 9, 2020 A friend of mine, also a miibox user, didnt have this problem with the previous version, but after latest update, he has this error too..He got tired of it, and bought appletv.
MembyR 0 Posted February 9, 2020 Posted February 9, 2020 Our media conversion feature can help with this. I tried remuxing it with MKVToolnix, didn't help. How could the media conversion feature help; it's a 4K HDR file, can it be converted without transcoding? Since I'm in the process of migrating from Plex to Emby, I tried playing the file in Plex and it skipped without any problem. Also, other players like MPC can seek without problems.
Cthalpa 11 Posted February 9, 2020 Posted February 9, 2020 I tried remuxing it with MKVToolnix, didn't help. How could the media conversion feature help; it's a 4K HDR file, can it be converted without transcoding? Since I'm in the process of migrating from Plex to Emby, I tried playing the file in Plex and it skipped without any problem. Also, other players like MPC can seek without problems. There is issues in the 20191227 release, thats for sure! Perhaps wait untill they get things fixed.
MembyR 0 Posted February 9, 2020 Posted February 9, 2020 There is issues in the 20191227 release, thats for sure! Perhaps wait untill they get things fixed. Indeed, for the biggest part Emby is delivering quite a positive experience so far!
Cthalpa 11 Posted February 9, 2020 Posted February 9, 2020 Indeed, for the biggest part Emby is delivering quite a positive experience so far! Agreed, their willingness to fix stuff is above and beyond, I just hope that they wont take too long to fix all these issues with this new release for firestick and atv
ebr 16338 Posted February 9, 2020 Posted February 9, 2020 Agreed, their willingness to fix stuff is above and beyond, I just hope that they wont take too long to fix all these issues with this new release for firestick and atv Hi. Can you please provide details for all the issues you are referring to? Other than a few random issues like this one that appear to be related to particular media, we aren't aware of any. Thanks.
Cthalpa 11 Posted February 9, 2020 Posted February 9, 2020 @@ebr-Random app startup and navigation crashes. -Long app load time (30+ seconds). -Unability to fast forward/backwards (sometimes app crashes when you try). We have another thread about these issues. My neighbor (and friend) has experienced all of the above as well, and a few other issues, and got so annoyed by this new release for android TV that he went out to get a $200 appletv.Ive sent a ton of logs/reports directly from the tv, supplied you with several videos and logs as well as tried to be "professional about it", but now its just honestly starting to get on my nerves!
Luke 42246 Posted February 11, 2020 Posted February 11, 2020 Are you still having an issue with fast forwarding?
