spudgun 0 Posted February 7, 2020 Posted February 7, 2020 (edited) Hi, I got some movies with multiple versions in the same directory (usually 2160p UHD remuxes and 1080p reencodes). I have set Internet streaming bitrate limit to 20Mbit and disabled trancoding of video for all users. Still it will try to direct stream the 2160p version (even if a 1080p reencoded version exists) for clients (both LG apps and AppleTV apps atleast). Am I doing something wrong? See attached log. ffmpeg-remux-c33f7569-5797-4971-81c8-6c1109044dc3_1.txt Edited February 7, 2020 by spudgun
Luke 42246 Posted February 7, 2020 Posted February 7, 2020 Hi, was this request actually from outside your network?
spudgun 0 Posted February 7, 2020 Author Posted February 7, 2020 Yes, the request was from a friend's house.
Luke 42246 Posted February 7, 2020 Posted February 7, 2020 Can you attach the corresponding emby server log from that ffmpeg log? thanks.
spudgun 0 Posted February 7, 2020 Author Posted February 7, 2020 Here is the server-log for the same timespan. Let me know if you need more logs/info. embyserver.txt
spudgun 0 Posted February 12, 2020 Author Posted February 12, 2020 Did you see what went wrong? He did try again. On all movies with 2160p HEVC/1080p reencoded versions it will chose the wrong version to direct stream (on high bitrate blurays howerver, it will chose the reencoded version). Here's another log if you need it. embyserver2.txt
Luke 42246 Posted February 13, 2020 Posted February 13, 2020 Please attach the complete emby server log as these are only snippets. Also please try granting access to video transcoding and see if that makes a difference. Thanks.
spudgun 0 Posted February 14, 2020 Author Posted February 14, 2020 (edited) Here is a full log file for today. I will try enabling transcoding for video as well to see if that helps. embyserver.txt ffmpeg-remux-5bac7ae9-d41c-4946-87b6-1d3703eb2a33_1.txt Edited February 14, 2020 by spudgun
Luke 42246 Posted February 14, 2020 Posted February 14, 2020 Thanks please let me know if that makes a difference.
Luke 42246 Posted February 14, 2020 Posted February 14, 2020 Although I think i might be good with these examples. I've made an adjustment that I think will resolve this for the next release. Thanks.
spudgun 0 Posted February 19, 2020 Author Posted February 19, 2020 It works in 4.4.0.15-beta. Thanks!
