Vinny1967 3 Posted February 6, 2020 Posted February 6, 2020 I've been trying to log into Emby Connect but it keeps telling me that my password or user name is invalid.It worked 2 days ago and I haven't changed anything.If I click on " Forgot Password" and fill in my user name,it tells me to contact my local administrator.Any ideas ? Cheers Vinny
Luke 42216 Posted February 6, 2020 Posted February 6, 2020 Hi, did you contact your local administrator? Is this your emby server or someone else's?
Vinny1967 3 Posted February 6, 2020 Author Posted February 6, 2020 Hi, did you contact your local administrator? Is this your emby server or someone else's? I use my own server.I also use Baconfeet but it doesn't make any difference which server I select.Same result every time.
Luke 42216 Posted February 7, 2020 Posted February 7, 2020 Do you know the difference between Emby Connect and the local user logins on those servers? It sounds like you're trying to use our cloud Emby Connect login on the local login screen of those servers. You should be using the local logins if that's what you're doing. What Emby app are you trying to use?
