jonathan.gorbutt 6 Posted February 5, 2020 Posted February 5, 2020 Don't know if this is how it supposed to but I've added Trakt to my server all working fine and still is but the PIN for my user is missing? I added the PIN saved it refreshed and it was still there but now its gone? - my server is still syncing to trakt etc as far as I can tell but seems wierd the PIN disappeared? when I check the plugin settings? Anyone know anything about this? Many Thanks -Jonathan
Gilgamesh_48 1243 Posted February 5, 2020 Posted February 5, 2020 The field blanks after a bit or exiting the Trakt Settings menu. It is normal and as long as your Trakt system is working it is nothing to worry about. I've been running off the same pin for about 10 months and it shows blank in the settings menu.
