troyhough 61 Posted February 4, 2020 Posted February 4, 2020 I installed the Emby for Android app on my Chromebook (through the Play Store) and the audio track sounds like the surround track. No words/talking, just the background noise????? Know of a fix for this? Emby Version: 3.0.97 Thanks
Luke 42243 Posted February 4, 2020 Posted February 4, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks ! 1
troyhough 61 Posted February 4, 2020 Author Posted February 4, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks ! Ok just sent the logs over via PM. Watched Bless This Mess S01E01. Let me know if it gives you what you need. Thanks @@Luke
Luke 42243 Posted February 5, 2020 Posted February 5, 2020 Have you made sure to configure your system audio settings?
troyhough 61 Posted February 5, 2020 Author Posted February 5, 2020 Chromebook system settings? or Emby app settings on the Chromebook?
troyhough 61 Posted February 5, 2020 Author Posted February 5, 2020 Chromebook system settings? or Emby app settings on the Chromebook? I don't think there any audio settings to modify in Chromebook. They are what they are??? Same goes for the Emby app, other than English, Spanish, etc???
troyhough 61 Posted February 5, 2020 Author Posted February 5, 2020 Is this consistent? Yes, consistent. Just sent you a PM. It only appears to fail when it's a Surround audio track. It plays back Stereo audio tracks perfectly.
troyhough 61 Posted February 6, 2020 Author Posted February 6, 2020 (edited) Yes. To clarify, @@Luke, it appears to always be direct playing on the Chromebook (according to the Server Dashboard). Both when audio is playing properly and not playing properly. Edited February 6, 2020 by troyhough
troyhough 61 Posted February 7, 2020 Author Posted February 7, 2020 @@Luke, Just tested all the same movies/files with the "Chrome Emby Web 4.3.1.32" on the Chromebook and all play the sound fine. Some transcode and some Direct Play, but sound worked on all. Just a heads up.
troyhough 61 Posted February 15, 2020 Author Posted February 15, 2020 HI @@Luke Has there been a fix to get audio on the Chromebook? Thanks
Luke 42243 Posted February 15, 2020 Posted February 15, 2020 No, we're still looking into it. Thanks.
troyhough 61 Posted February 15, 2020 Author Posted February 15, 2020 No, we're still looking into it. Thanks. Ok thank you.
scaldeddog79 0 Posted March 3, 2020 Posted March 3, 2020 Wanted to chime in and report I am experiencing the same issue on a Samsung Pro Chromebook. Only getting surround channels, no dialogue/center channel content, when using the android app. Playback via the browser web-app interface was fine.
troyhough 61 Posted March 12, 2020 Author Posted March 12, 2020 Just a heads up that I fired up the Chromebook today. There was an OS update along with an Emby app update. I applied both, rebooted, and the "no sound" persists.
sicofthis 0 Posted March 22, 2020 Posted March 22, 2020 I'm experiencing the same issue with losing the dialog in chromebook app. Background music plays fine.
Luke 42243 Posted March 26, 2020 Posted March 26, 2020 I got a new Chromebook and I can reproduce this now. We're looking into it. 1
troyhough 61 Posted April 14, 2020 Author Posted April 14, 2020 Just an update... I just powered up my Chromebook for the first time in a while. There was an Emby update and Chrome OS update. Problem still persists after updating both...
teiva 18 Posted April 25, 2020 Posted April 25, 2020 (edited) Devices Emby Server 4.4.2.0Pixel XL (QP1A.191005.007.A3) Pixel 2 XL (QQ2A.200405.005) ChromeOS (Version 81.0.4044.127 ) Sony WH-1000XM3 Bluetooth headphones (current firmware 4.2.2) Actual Behavior: It's as if the left and right speakers are playing sound but the center dialogue speaker is not coming through. It's actually been like this for a while now. Sorry for not reporting sooner. When does the dialogue sound work... 1. Pixel XL / Pixel 2 XL (alone) 2. ChromeOS (alone) 3. ChromeOS + Sony headphones via bluetooth When does the dialogue sound not work... 1. Pixel XL / Pixel 2 XL + Sony headphones via bluetooth All scenarios were tested with the same video. When it doesn't work ...it doesn't work with all AC3, eAC3 & DTS audio codecs. Edited April 25, 2020 by teiva 1
teiva 18 Posted April 25, 2020 Posted April 25, 2020 2020-04-25 10:45:22.642 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.643 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.643 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.643 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.643 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.643 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.643 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.643 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.643 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.643 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.643 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.643 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.657 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.658 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.658 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.658 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.658 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.658 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.658 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.658 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.659 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:22.807 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:45:22.810 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:45:22.893 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.893 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:40:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:45:22.893 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:45:32.801 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:45:32.804 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:45:41.833 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:45:41.834 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:45:41.837 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:45:41.839 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:45:42.811 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:45:42.813 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:45:52.804 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:45:52.807 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:01.834 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:46:01.834 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:01.837 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:46:01.840 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:02.804 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:46:02.807 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:12.803 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:46:12.806 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:21.833 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:46:21.834 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:21.837 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:46:21.839 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:22.802 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:46:22.804 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:31.836 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:46:31.837 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:31.841 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:46:31.843 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:32.814 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:46:32.817 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:42.801 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:46:42.803 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:51.834 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:46:51.835 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:51.838 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:46:51.840 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:46:52.809 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:46:52.815 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:02.801 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:47:02.804 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:11.836 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:47:11.836 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:11.839 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:47:11.923 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 84ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:12.816 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:47:12.819 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:22.803 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:47:22.805 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:31.837 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:47:31.837 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:31.841 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:47:31.844 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:32.814 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:47:32.816 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:35.081 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:47:35.083 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:35.943 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:47:35.946 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:46.929 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:47:46.932 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:51.838 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:47:51.839 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:51.841 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:47:51.844 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:47:56.948 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:47:57.035 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 87ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:00.529 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:48:00.531 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:01.838 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:48:01.839 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:01.841 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:48:01.843 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:02.817 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:48:02.820 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:12.807 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:48:12.810 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:21.837 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:48:21.838 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:21.840 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:48:21.843 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:22.808 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:48:22.811 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:31.840 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:48:31.840 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:31.843 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:48:31.845 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:32.809 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:48:32.812 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:42.797 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:48:42.799 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:51.839 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:48:51.839 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:51.842 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:48:51.844 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:48:52.814 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:48:52.817 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:02.816 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:49:02.819 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:11.841 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:49:11.841 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:11.846 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:49:11.848 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:12.815 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:49:12.818 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:22.804 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:49:22.806 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:31.840 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:49:31.840 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:31.843 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:49:31.846 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:32.809 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:49:32.811 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:42.804 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:49:42.807 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:51.841 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:49:51.841 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:51.845 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:49:51.847 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:49:52.808 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:49:52.811 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:02.803 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:50:02.805 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:11.840 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:50:11.840 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:11.842 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:50:11.932 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 89ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:12.305 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; nami Build/R81-12871.91.0) 2020-04-25 10:50:12.306 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/emby/system/info/public?format=json 2020-04-25 10:50:12.325 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sync/data. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; nami Build/R81-12871.91.0) 2020-04-25 10:50:12.326 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Sync/Items/Ready?TargetId=137826d3aa5093cb. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; nami Build/R81-12871.91.0) 2020-04-25 10:50:12.343 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 18ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sync/data 2020-04-25 10:50:12.343 Debug App: Returning 0 ready sync items for targetId 137826d3aa5093cb 2020-04-25 10:50:12.344 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 17ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sync/Items/Ready?TargetId=137826d3aa5093cb 2020-04-25 10:50:12.811 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:50:12.814 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:21.841 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:50:21.842 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:21.845 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:50:21.848 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:22.806 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:50:22.809 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:32.810 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:50:32.812 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:41.842 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:50:41.842 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:41.845 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:50:41.848 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:42.798 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:50:42.800 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:52.809 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:50:52.816 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 6ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:50:59.138 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Sync/Items/Ready?TargetId=1b29719592348e6b. UserAgent: Dalvik/2.1.0 (Linux; U; Android 10; Pixel XL Build/QP1A.191005.007.A3) 2020-04-25 10:50:59.223 Debug App: Returning 0 ready sync items for targetId 1b29719592348e6b 2020-04-25 10:50:59.223 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 86ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sync/Items/Ready?TargetId=1b29719592348e6b 2020-04-25 10:50:59.354 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sync/data. UserAgent: Dalvik/2.1.0 (Linux; U; Android 10; Pixel XL Build/QP1A.191005.007.A3) 2020-04-25 10:50:59.356 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sync/data 2020-04-25 10:51:01.843 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:51:01.843 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:01.847 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:51:01.849 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:02.804 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:51:02.806 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:12.885 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:51:12.888 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:21.843 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:51:21.843 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:21.846 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:51:21.849 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:22.807 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:51:22.810 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:32.812 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:51:32.815 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:41.842 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:51:41.842 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:41.844 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:51:41.845 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:42.809 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:51:42.812 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:51.844 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:51:51.844 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:51.848 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:51:51.851 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:51:52.803 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:51:52.806 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:02.811 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:52:02.814 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:11.844 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:52:11.844 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:11.847 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:52:11.849 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:12.805 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:52:12.808 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:22.815 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:52:22.817 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:31.847 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:52:31.847 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:31.849 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:52:31.852 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:32.808 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:52:32.811 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:42.817 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:52:42.820 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:51.844 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:52:51.845 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:51.848 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:52:51.850 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:52:52.806 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:52:52.808 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:01.847 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:01.847 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:01.852 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:01.855 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:02.809 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:02.812 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:11.090 Info HttpServer: HTTP GET http://50.54.137.211:8007/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.102 Safari/537.36 Edge/18.18363 2020-04-25 10:53:11.091 Info HttpServer: HTTP Response 200 to 73.19.109.35. Time: 1ms. http://50.54.137.211:8007/emby/system/info/public 2020-04-25 10:53:11.117 Info HttpServer: HTTP GET http://50.54.137.211:8007/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.102 Safari/537.36 Edge/18.18363 2020-04-25 10:53:11.248 Info HttpServer: HTTP Response 200 to 73.19.109.35. Time: 131ms. http://50.54.137.211:8007/emby/System/Info 2020-04-25 10:53:11.293 Info HttpServer: HTTP GET http://50.54.137.211:8007/emby/DisplayPreferences/usersettings?userId=26b96b83b977419594bec1333fc9ce26&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.102 Safari/537.36 Edge/18.18363 2020-04-25 10:53:11.295 Info HttpServer: HTTP Response 200 to 73.19.109.35. Time: 2ms. http://50.54.137.211:8007/emby/DisplayPreferences/usersettings?userId=26b96b83b977419594bec1333fc9ce26&client=emby 2020-04-25 10:53:11.426 Info HttpServer: HTTP GET http://50.54.137.211:8007/emby/Sync/Items/Ready?TargetId=bsUt42zDgKcoyWGx0u1hLiywHy6NH1jyvpFAJgqBU. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.102 Safari/537.36 Edge/18.18363 2020-04-25 10:53:11.428 Debug App: Returning 0 ready sync items for targetId bsUt42zDgKcoyWGx0u1hLiywHy6NH1jyvpFAJgqBU 2020-04-25 10:53:11.428 Info HttpServer: HTTP Response 200 to 73.19.109.35. Time: 3ms. http://50.54.137.211:8007/emby/Sync/Items/Ready?TargetId=bsUt42zDgKcoyWGx0u1hLiywHy6NH1jyvpFAJgqBU 2020-04-25 10:53:11.445 Info HttpServer: HTTP POST http://50.54.137.211:8007/emby/Sync/Data. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; MSAppHost/3.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.102 Safari/537.36 Edge/18.18363 2020-04-25 10:53:11.447 Info HttpServer: HTTP Response 200 to 73.19.109.35. Time: 2ms. http://50.54.137.211:8007/emby/Sync/Data 2020-04-25 10:53:12.809 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:12.812 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:21.846 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:21.847 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:21.851 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:21.931 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 80ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:22.810 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:22.813 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:32.808 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:32.811 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:41.846 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:41.846 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:41.848 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:41.851 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:42.817 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:42.819 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:49.578 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/241555. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:49.583 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Items/241555/ThemeMedia?UserId=1422700c61ff4bc193eb051f6e0725d6&InheritFromParent=true&EnableThemeSongs=true&EnableThemeVideos=false. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:49.583 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:49.583 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6 2020-04-25 10:53:49.584 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Items/241555/ThemeMedia?UserId=1422700c61ff4bc193eb051f6e0725d6&InheritFromParent=true&EnableThemeSongs=true&EnableThemeVideos=false 2020-04-25 10:53:49.584 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 7ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/241555 2020-04-25 10:53:49.619 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:49.621 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6 2020-04-25 10:53:49.621 Info HttpServer: SocketException: http://xxx.xxx.xxx.xx:xxxx/emby/videos/241570/stream.mkv?DeviceId=1b29719592348e6b&MediaSourceId=0e905cb9db0cea7dc972aa8d57427eb3&Static=true&PlaySessionId=8cdc2494013c4f6e8ce0d68afe6a7ac6&api_key=03e1b0132f57420bb35139c7927bcce3 2020-04-25 10:53:49.621 Info HttpServer: HTTP Response 206 to xxx.xxx.xxx.xx. Time: 626894ms. http://xxx.xxx.xxx.xx:xxxx/emby/videos/241570/stream.mkv?DeviceId=1b29719592348e6b&MediaSourceId=0e905cb9db0cea7dc972aa8d57427eb3&Static=true&PlaySessionId=8cdc2494013c4f6e8ce0d68afe6a7ac6 2020-04-25 10:53:49.633 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:49.635 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6 2020-04-25 10:53:50.083 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Stopped. UserAgent: Mozilla/5.0 (Linux; Android 10; Pixel XL Build/QP1A.191005.007.A3; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/xx.x.xxxx.111 Mobile Safari/537.36 2020-04-25 10:53:50.092 Debug PlaystateService: ReportPlaybackStopped PlaySessionId: 8cdc2494013c4f6e8ce0d68afe6a7ac6 2020-04-25 10:53:50.092 Info SessionManager: Playback stopped reported by app Emby for Android Mobile 3.1.19 playing xxxxxx. Stopped at 349000 ms 2020-04-25 10:53:50.093 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 11ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Stopped 2020-04-25 10:53:50.109 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-04-18T17%3A48%3A33.692Z&hasUserId=false. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:50.109 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-04-24T17%3A48%3A33.689Z&hasUserId=true. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:50.109 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-04-18T17%3A48%3A33.692Z&hasUserId=false 2020-04-25 10:53:50.109 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-04-24T17%3A48%3A33.689Z&hasUserId=true 2020-04-25 10:53:50.112 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-04-18T17%3A48%3A33.692Z&hasUserId=false. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:50.112 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-04-24T17%3A48%3A33.689Z&hasUserId=true. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:50.xx7 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-04-24T17%3A48%3A33.731Z&hasUserId=true. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:50.xx8 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-04-24T17%3A48%3A33.731Z&hasUserId=true 2020-04-25 10:53:50.xx8 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-04-18T17%3A48%3A33.732Z&hasUserId=false. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:50.xx9 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-04-18T17%3A48%3A33.732Z&hasUserId=false 2020-04-25 10:53:50.153 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-04-24T17%3A48%3A33.731Z&hasUserId=true. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:50.153 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-04-18T17%3A48%3A33.732Z&hasUserId=false. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:50.195 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 82ms. http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-04-18T17%3A48%3A33.692Z&hasUserId=false 2020-04-25 10:53:50.197 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 84ms. http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-04-24T17%3A48%3A33.689Z&hasUserId=true 2020-04-25 10:53:50.198 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 45ms. http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=7&MinDate=2020-04-24T17%3A48%3A33.731Z&hasUserId=true 2020-04-25 10:53:50.200 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 47ms. http://xxx.xxx.xxx.xx:xxxx/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2020-04-18T17%3A48%3A33.732Z&hasUserId=false 2020-04-25 10:53:51.848 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:51.848 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:53:51.851 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:53:51.854 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:54:01.412 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:01.412 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:01.412 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6c2a057148b4d7c20a207c789aba6d07. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:01.413 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2020-04-25 10:54:01.413 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6c2a057148b4d7c20a207c789aba6d07 2020-04-25 10:54:01.413 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2020-04-25 10:54:01.417 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:01.417 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:01.417 Info HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6c2a057148b4d7c20a207c789aba6d07. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.91.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:01.424 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 7ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video 2020-04-25 10:54:01.431 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 13ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2020-04-25 10:54:01.436 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 19ms. http://xxx.xxx.xxx.xx:xxxx/emby/Users/1422700c61ff4bc193eb051f6e0725d6/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6c2a057148b4d7c20a207c789aba6d07 2020-04-25 10:54:11.848 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:11.849 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:54:11.851 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:11.854 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:54:21.849 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:21.849 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:54:21.853 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:21.856 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:54:41.852 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:41.852 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:54:41.855 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:54:41.857 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:55:01.850 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:55:01.850 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 0ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:55:01.853 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:55:01.855 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 2ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:55:21.848 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:55:21.856 Info HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 7ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:55:21.859 Info HttpServer: HTTP POST http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 2020-04-25 10:55:21.862 Info HttpServer: HTTP Response 204 to xxx.xxx.xxx.xx. Time: 3ms. http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress 2020-04-25 10:55:22.324 Debug App: Begin Sending Alive Notifications For All Devices 2020-04-25 10:55:22.324 Debug App: Sending alive notification MediaServer - 21a246ac1f354d069e044cfd89933b42 2020-04-25 10:55:22.325 Debug App: Sending alive notification MediaServer - 21a246ac1f354d069e044cfd89933b42 2020-04-25 10:55:22.325 Debug App: Sending alive notification MediaServer - 21a246ac1f354d069e044cfd89933b42 2020-04-25 10:55:22.325 Debug App: Sending alive notification ContentDirectory - 21a246ac1f354d069e044cfd89933b42 2020-04-25 10:55:22.325 Debug App: Sending alive notification ContentDirectory - 21a246ac1f354d069e044cfd89933b42 2020-04-25 10:55:22.325 Debug App: Sending alive notification ConnectionManager - 21a246ac1f354d069e044cfd89933b42 2020-04-25 10:55:22.325 Debug App: Sending alive notification ConnectionManager - 21a246ac1f354d069e044cfd89933b42 2020-04-25 10:55:22.325 Debug App: Completed Sending Alive Notifications For All Devices 2020-04-25 10:55:22.407 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.407 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.407 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.407 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.407 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.407 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.408 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.408 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.408 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.408 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.408 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.409 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.409 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.409 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.410 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.428 Debug PortMapper: Found NAT device: uuid:00000027-f51f-7667-af16-2c584f64d180::urn:schemas-upnp-org:service:WANIPConnection:1 2020-04-25 10:55:22.428 Debug PortMapper: Found device at: http://xxx.xxx.xxx.xxx:xxxx/devdescr.xml 2020-04-25 10:55:22.428 Debug HttpClient: GET http://xxx.xxx.xxx.xxx:xxxx/devdescr.xml 2020-04-25 10:55:22.434 Debug PortMapper: Found NAT device: uuid:00000027-f51f-7667-af16-2c584f64d180::urn:schemas-upnp-org:service:WANPPPConnection:1 2020-04-25 10:55:22.434 Debug PortMapper: Found device at: http://xxx.xxx.xxx.xxx:xxxx/devdescr.xml 2020-04-25 10:55:22.434 Debug HttpClient: GET http://xxx.xxx.xxx.xxx:xxxx/devdescr.xml 2020-04-25 10:55:22.437 Debug PortMapper: xxx.xxx.xxx.xxx:xxxx: Found upnp service urn:schemas-upnp-org:service:WANIPConnection:1 at /wipc_cont 2020-04-25 10:55:22.437 Debug PortMapper: xxx.xxx.xxx.xxx:xxxx: Found upnp service urn:schemas-upnp-org:service:WANPPPConnection:1 at /wpppc_cont 2020-04-25 10:55:22.437 Debug PortMapper: Creating port map on local port 8007 to public port 8007 with device xxx.xxx.xxx.xx 2020-04-25 10:55:22.437 Debug HttpClient: POST http://xxx.xxx.xxx.xxx:xxxx/wipc_cont 2020-04-25 10:55:22.439 Debug PortMapper: xxx.xxx.xxx.xxx:xxxx: Found upnp service urn:schemas-upnp-org:service:WANIPConnection:1 at /wipc_cont 2020-04-25 10:55:22.439 Debug PortMapper: xxx.xxx.xxx.xxx:xxxx: Found upnp service urn:schemas-upnp-org:service:WANPPPConnection:1 at /wpppc_cont 2020-04-25 10:55:22.499 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.500 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.500 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.500 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.500 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.500 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.500 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.500 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.501 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.501 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.501 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:05 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.501 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.501 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.501 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.501 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.520 Error HttpClient: <?xml version="1.0"?> <SOAP:Envelope xmlns:SOAP="http://schemas.xmlsoap.org/soap/envelope/" SOAP:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP:Body> <SOAP:Fault> <faultcode>SOAP:Client</faultcode> <faultstring>UPnPError</faultstring> <detail> <UPnPError xmlns="urn:schemas-upnp-org:control-1-0"> <errorCode>401</errorCode> <errorDescription>Invalid action</errorDescription> </UPnPError> </detail> </SOAP:Fault> </SOAP:Body> </SOAP:Envelope> 2020-04-25 10:55:22.521 Debug HttpClient: POST http://xxx.xxx.xxx.xxx:xxxx/wipc_cont 2020-04-25 10:55:22.523 Error HttpClient: <?xml version="1.0"?> <SOAP:Envelope xmlns:SOAP="http://schemas.xmlsoap.org/soap/envelope/" SOAP:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP:Body> <SOAP:Fault> <faultcode>SOAP:Client</faultcode> <faultstring>UPnPError</faultstring> <detail> <UPnPError xmlns="urn:schemas-upnp-org:control-1-0"> <errorCode>401</errorCode> <errorDescription>Invalid action</errorDescription> </UPnPError> </detail> </SOAP:Fault> </SOAP:Body> </SOAP:Envelope> 2020-04-25 10:55:22.527 Error PortMapper: Error creating port map *** Error Report *** Version: 4.4.2.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.19.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 8 Program data path: /config Application directory: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.GetSpecificMappingAsync(Protocol protocol, Int32 publicPort, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2020-04-25 10:55:22.527 Debug PortMapper: Creating port map on local port xxxx to public port xxxx with device xxx.xxx.xxx.xx 2020-04-25 10:55:22.527 Debug HttpClient: POST http://xxx.xxx.xxx.xxx:xxxx/wipc_cont 2020-04-25 10:55:22.529 Error HttpClient: <?xml version="1.0"?> <SOAP:Envelope xmlns:SOAP="http://schemas.xmlsoap.org/soap/envelope/" SOAP:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP:Body> <SOAP:Fault> <faultcode>SOAP:Client</faultcode> <faultstring>UPnPError</faultstring> <detail> <UPnPError xmlns="urn:schemas-upnp-org:control-1-0"> <errorCode>401</errorCode> <errorDescription>Invalid action</errorDescription> </UPnPError> </detail> </SOAP:Fault> </SOAP:Body> </SOAP:Envelope> 2020-04-25 10:55:22.530 Debug HttpClient: POST http://xxx.xxx.xxx.xxx:xxxx/wipc_cont 2020-04-25 10:55:22.580 Error HttpClient: <?xml version="1.0"?> <SOAP:Envelope xmlns:SOAP="http://schemas.xmlsoap.org/soap/envelope/" SOAP:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP:Body> <SOAP:Fault> <faultcode>SOAP:Client</faultcode> <faultstring>UPnPError</faultstring> <detail> <UPnPError xmlns="urn:schemas-upnp-org:control-1-0"> <errorCode>401</errorCode> <errorDescription>Invalid action</errorDescription> </UPnPError> </detail> </SOAP:Fault> </SOAP:Body> </SOAP:Envelope> 2020-04-25 10:55:22.582 Error PortMapper: Error creating port map *** Error Report *** Version: 4.4.2.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.19.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 8 Program data path: /config Application directory: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.GetSpecificMappingAsync(Protocol protocol, Int32 publicPort, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2020-04-25 10:55:22.599 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.599 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.599 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.599 Debug HttpServer: HTTP GET http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml. UserAgent: Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.599 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.600 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.600 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.600 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.600 Debug Dlna: No matching device profile found. HOST=xxx.xxx.xxx.xx:xxxx, DATE=Sat, 25 Apr 2020 17:50:06 GMT, CONNECTION=close, USER-AGENT=Linux/3.18.27, UPnP/1.0, Portable SDK for UPnP devices/1.8.0 2020-04-25 10:55:22.600 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.600 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:22.601 Debug HttpServer: HTTP Response 200 to xxx.xxx.xxx.xx. Time: 1ms. http://xxx.xxx.xxx.xx:xxxx/dlna/21a246ac1f354d069e044cfd89933b42/description.xml 2020-04-25 10:55:41.850 Info HttpServer: HTTP OPTIONS http://xxx.xxx.xxx.xx:xxxx/emby/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (X11; CrOS x86_64 12871.76.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xxx Safari/537.36 1
