Doctor Bob 9 Posted February 23, 2021 Author Posted February 23, 2021 (edited) After installing EMC218 I see this in the Media Center when I select EMC. I also tried a uninstall and then installed again. Same s above. Edited February 23, 2021 by Doctor Bob
dansblackcat 37 Posted February 24, 2021 Posted February 24, 2021 9 hours ago, One2Go said: What device did you use to watch the Emby Theater on and if it is a HTPC what type of themes? Yes I use a HTPC. I haven't explored any themes yet, just the default. Anything you recommend?
dansblackcat 37 Posted February 24, 2021 Posted February 24, 2021 16 hours ago, MikeyMan said: At the same time; if you have to force yourself; the interface is probably less user friendly My main reason for using WMC is simply; user friendliness with my IR remote on my HTPC. Agreed. But I feel less user friendly is also just less familiar. I now find that I wish EMC had some of the features that I'm used to in theatre. Simplicity was also my main reason for WMC. In all fairness Theatre has come along way from when I first tried it. The last few updates have ironed out tons of bugs for me. It's pretty friendly with the media centre remote too. Only thing missing for me these days is the ability to jump to a letter using the number keys on the remote.
One2Go 120 Posted February 24, 2021 Posted February 24, 2021 2 hours ago, dansblackcat said: Yes I use a HTPC. I haven't explored any themes yet, just the default. Anything you recommend? I use EMC with the Throgsoft themes here and use external players MPC for anything except Blu-Ray or DVDs. Just search for Throgsoft or Throgmorton and you will see screenshots of the different themes. I do use an extended Home Screen that shows all the libraries.
MikeyMan 8 Posted February 24, 2021 Posted February 24, 2021 (edited) Get the message 'there is something wrong with this installer package'... Does seem to work though... Although it doesnt fix the issue. I've got: 9,10,11,12,13,14,1,2,3,4,5,6,7,8,15,16,17,18,19 with blue bloods season 10 for instance. And no logic with alphabetical order. Edited February 24, 2021 by MikeyMan
ebr 16331 Posted February 24, 2021 Posted February 24, 2021 What version of the app is shown in the config page? Doesn't sound like it actually installed.
Doctor Bob 9 Posted February 24, 2021 Author Posted February 24, 2021 (edited) Okay, ebr that did it. The TV episodes now appear in ascending order. This might have been just a one-off but at the end of the MediaBrowser.msi installation I saw this: Edited February 24, 2021 by Doctor Bob
ebr 16331 Posted February 24, 2021 Posted February 24, 2021 7 minutes ago, MikeyMan said: Could that be 3.0.318.0? Yes. And you are getting a different result than DrBob?
MikeyMan 8 Posted February 24, 2021 Posted February 24, 2021 Yes I am. Like I said in the example sequence for blue bloods above.
ebr 16331 Posted February 24, 2021 Posted February 24, 2021 13 minutes ago, MikeyMan said: Yes I am. Like I said in the example sequence for blue bloods above. What theme are you using? Also, make sure those episodes are properly identified with season and episode numbers...
MikeyMan 8 Posted February 25, 2021 Posted February 25, 2021 I'm using the chocolate theme. Never did any manual intervention with seasons and numbers. Just got out of whack at some point. example from blue bloods: Same happens to all series with 10+ episodes it seems.
ebr 16331 Posted February 25, 2021 Posted February 25, 2021 Can you bring up "Grave Errors" in the metadata editor on the web app and show me what is in the season and episode number fields? Are you saying that the previous seasons are sorted correctly?
MikeyMan 8 Posted February 25, 2021 Posted February 25, 2021 Sure! For Blue Bloods I don't have the preceding seasons anymore. But for chicago fire: Season 6 ok. Season 7 ok. Season 8 starts with 9 again. Season 9 so far ok, but only 7 episodes until now.
dejavux2 47 Posted March 3, 2021 Posted March 3, 2021 Is there a way to roll this back if it doesn't work? Just asking....
dejavux2 47 Posted March 3, 2021 Posted March 3, 2021 (edited) @Luke YAY!!!! I'm so happy!! Edited March 3, 2021 by dejavux2
Doctor Bob 9 Posted March 3, 2021 Author Posted March 3, 2021 1 minute ago, dejavux2 said: YAY!!!! I'm so happy!! Most excellent!
dejavux2 47 Posted March 3, 2021 Posted March 3, 2021 I've been going crazy trying to update every single episode of every single show with a Sort Name in the Metadata Manager.
Doctor Bob 9 Posted March 3, 2021 Author Posted March 3, 2021 2 hours ago, dejavux2 said: I've been going crazy trying to update every single episode of every single show with a Sort Name in the Metadata Manager. I was also thinking about using the title sort option in the Metadata Manager to straighten out all my TV episodes. Thank you ebr for providing the EMC update.
MikeyMan 8 Posted April 15, 2021 Posted April 15, 2021 I still don't understand why the issue persists for me... Even with the last updated version...? Newer seasons look ok btw.
ebr 16331 Posted April 15, 2021 Posted April 15, 2021 1 hour ago, MikeyMan said: I still don't understand why the issue persists for me... Even with the last updated version...? Newer seasons look ok btw. What is in the SortTitle field of the episodes that sort incorrectly?
Guest Posted April 15, 2021 Posted April 15, 2021 I would be wondering about the embedded data.. and what it said as well...if those tags are read regardless of what additional external information is gathered it may not overwrite the information gathered, present in the file.
