ebr 16313 Posted February 4, 2020 Posted February 4, 2020 I thought it was 2:3? Not once it goes in that CA treatment which adds a bar to the top.
Luke 42216 Posted February 4, 2020 Posted February 4, 2020 Right it's close enough to 2:3 so that's why the web app stretches it.
ebr 16313 Posted February 4, 2020 Posted February 4, 2020 Still not sure on which screen this is but, if the web app is respecting the reported aspect ratio, it is possible that CA is not determining it correctly in some instances... I seem to recall way back that getting that completely accurate could be a performance problem but my memory is admittedly fuzzy on that.
ebr 16313 Posted February 4, 2020 Posted February 4, 2020 It's the library screen. What is "the library screen"? There are several ways to view any particular library.
crusher11 1137 Posted February 4, 2020 Author Posted February 4, 2020 From the home screen, I clicked on the library.
ebr 16313 Posted February 4, 2020 Posted February 4, 2020 From the home screen, I clicked on the library. When you do that there are seven different places you could possibly end up. Which one are you on (tabs at the top)?
