nonjtjt 1 Posted May 3, 2020 Posted May 3, 2020 And work well with 1.0.10 too. So my opinion just try to reset the samsung hub and try install again. And it's work! Thanks so much, I'm happy now.
FrostByte 5453 Posted May 3, 2020 Posted May 3, 2020 BTW I reseted the Samsung hub and try on 1.0.6 again seems to be work perfectly. Question is does I have to keep those zip file on my server or not? No, you don't need the zip or IIS installed on your Windows machine anymore unless for some reason you had to reinstall. Since the devs for that app are gone there most likely won't be many updates either.
SamES 1084 Posted May 4, 2020 Posted May 4, 2020 And work well with 1.0.10 too. So my opinion just try to reset the samsung hub and try install again. And it's work! Thanks so much, I'm happy now. I would go with 1.0.10, it should work fine. There were just a few fixes for changes to the API on the server. Once it's installed you don't need the zips, but handy if you need to reinstall.
