dannymichel 104 Posted March 15, 2020 Author Posted March 15, 2020 Looks good with dark themes, not so much with the light ones... the top bars are not readable when using a light theme being 100% honest i forgot light themes existed i'll look into editing it for light as well 1
tomnjerry74 97 Posted March 15, 2020 Posted March 15, 2020 I think i'm satisfied with the latest update i've made to this. unless something comes up, i think that's the final edit. let me know if anything Nice changes, but episodes in individual seasons of shows still have the old play icon btw.
daedalus 434 Posted March 15, 2020 Posted March 15, 2020 you mean the season list view that view always was different from all the others and always makes "problems" for customizations and normal development, but they stick to it 1
dannymichel 104 Posted March 15, 2020 Author Posted March 15, 2020 Nice changes, but episodes in individual seasons of shows still have the old play icon btw. @@Luke changed it in the latest beta so I left it out.
tomnjerry74 97 Posted March 15, 2020 Posted March 15, 2020 @@Luke changed it in the latest beta so I left it out. Ah okay, that makes sense. Thanks for all your work
dannymichel 104 Posted March 15, 2020 Author Posted March 15, 2020 Ah okay, that makes sense. Thanks for all your work No problem brother
dannymichel 104 Posted March 16, 2020 Author Posted March 16, 2020 I kind of went nuts with the edits on this one, but if you want a more minimal edit that addresses the obvious issues, i've done one of those too css: https://www.dropbox.com/s/n7qzk6dywxm89j3/emby-minimal.css
dannymichel 104 Posted March 16, 2020 Author Posted March 16, 2020 Looks good with dark themes, not so much with the light ones... the top bars are not readable when using a light theme @@Dibbes grab the updated css That issue is fixed
Dibbes 515 Posted March 16, 2020 Posted March 16, 2020 @@Dibbes grab the updated css That issue is fixed if this is still the link https://www.dropbox.com/s/uxpjk7m54zdbbu7/emby.css then I don't see any differences when it comes to light themes... sorry
lkem 1 Posted March 16, 2020 Posted March 16, 2020 Hi @@dannymichel, is it required to have both wallpapers and banners disabled in settings to have screengrabs in "Next up" section? I would like to have them downloaded but not showing there
dannymichel 104 Posted March 16, 2020 Author Posted March 16, 2020 Hi @@dannymichel, is it required to have both wallpapers and banners disabled in settings to have screengrabs in "Next up" section? I would like to have them downloaded but not showing there i personally disable everything but 'primary' on all libraries
dannymichel 104 Posted March 16, 2020 Author Posted March 16, 2020 i got rid of the zoom in the latest update
lkem 1 Posted March 16, 2020 Posted March 16, 2020 i personally disable everything but 'primary' on all libraries Did that but now this happens in the "Upcoming" section:
dannymichel 104 Posted March 16, 2020 Author Posted March 16, 2020 Did that but now this happens in the "Upcoming" section: are you on the beta?
lkem 1 Posted March 16, 2020 Posted March 16, 2020 are you on the beta? No, im on 4.3.1.0, if its fixed in beta ill just wait
dannymichel 104 Posted March 18, 2020 Author Posted March 18, 2020 (edited) Update: got rid of unnecessary padding on top Edited March 18, 2020 by dannymichel
igeoorge 26 Posted March 18, 2020 Posted March 18, 2020 Hi @@dannymichel Congratulations on your great job, I'm really enjoying it. Please don't stop. Unfortunately I don't know much about CSS, so I would like to know if you can tell which part of the code only refers to this part: "An opacity color has been added to the hover for the play button"
mazafra 0 Posted March 19, 2020 Posted March 19, 2020 (edited) Edited. Edited March 19, 2020 by mazafra
Shidapu 14 Posted March 25, 2020 Posted March 25, 2020 Love the design. But i have some issue in the controlpanel. The following pages are black and text dont show correctly. ConversionsDownloadsDLNAAddonsAuto OrganizePlayback reporting Not sure why, maybe by design?
dannymichel 104 Posted March 25, 2020 Author Posted March 25, 2020 Love the design. But i have some issue in the controlpanel. The following pages are black and text dont show correctly. Conversions Downloads DLNA Addons Auto Organize Playback reporting Not sure why, maybe by design? yes, works best on dark control panel themes or now
Shidapu 14 Posted March 26, 2020 Posted March 26, 2020 (edited) yes, works best on dark control panel themes or now Yeah i figured Also, i noticed you have a nice bar at the top, mine just shows Home and Favorites. ?? Edited March 26, 2020 by Shidapu
tomnjerry74 97 Posted April 10, 2020 Posted April 10, 2020 Hey I've been using this CSS setup for a while and love it. The most recent emby server update seems to have broken the play button a little bit though. Is there a way to make it not zoom in on hover like it was before the update?
dannymichel 104 Posted April 11, 2020 Author Posted April 11, 2020 Hey I've been using this CSS setup for a while and love it. The most recent emby server update seems to have broken the play button a little bit though. Is there a way to make it not zoom in on hover like it was before the update? sure, i'll update it soon
johnhb 7 Posted January 5, 2021 Posted January 5, 2021 On 11/03/2020 at 18:44, AviatorBimmer said: Nice! I'll definitely check it out then, this afternoon after work. This only applies to the Emby Web, correct? It would be awesome if it could be a server change that gets pushed over to any client/app as well. FWIW I agree 100% with this. Saw a few related posts and I can't believe the Emby team would be doing anything other than biting off Danny's hand to have a pro consult on their graphics. For free. Just about all media centres are flawed by the lack of prof graphic design consultancy, it's nuts to pass up his offer. As a starter for 10, I would love to see these tweaks rolled out uniformly to all apps/clients with only minor tweaks for usability. Consistency massively helps usability and surely a consistent design is easier to maintain from a dev perspective too? I like the play icon and lower weight emby text in the first screen shot btw. Hate to say it but I agree with comments in other posts that the current logo and text looks cheap (it's as if costco released a media centre ). 1
