badous 17 Posted March 6, 2020 Posted March 6, 2020 I've changed the name to "mibox" then, I've rebooted the box, and, finally, all is fine now! Thank you for your time! And to say that I had thought of that from the start! Damn, i'vnt test name change! Thank you, I had the same issue after a reset of the mibox. I had to change the name too to fix it.
Auxilium 0 Posted January 10, 2021 Posted January 10, 2021 Issue with non-English characters in device name is still there... Device: Google TV AndroidTv 1.8.54g (Chromecast Google TV) Server: 4.5.4.0 App refused to login with error until I renamed the device from Russian to just plain English. Same error as this On 2/3/2020 at 2:59 PM, blap said: Hello ! Exact the same error ...a the same moment, just after i fill in the server and port form. After that, any login and password are marked false And exactly same logs as this On 1/31/2020 at 6:55 PM, blap said: i've forgot this with my grep in the log file 2020-01-31 18:44:07.058 Info HttpServer: HTTP GET http://my_server_ip.78:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; MIBOX4 Build/PI) 2020-01-31 18:44:07.059 Info HttpServer: HTTP Response 200 to 91.163.xx.xx. Time: 1ms. http://my_server_ip.78:8096/emby/system/info/public?format=json 2020-01-31 18:44:07.094 Info HttpServer: HTTP GET http://my_server_ip.78:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; MIBOX4 Build/PI) 2020-01-31 18:44:07.095 Info HttpServer: HTTP Response 200 to 91.163.xx.xx. Time: 1ms. http://my_server_ip.78:8096/emby/system/info/public?format=json 2020-01-31 18:44:22.788 Info HttpServer: HTTP GET http://my_server_ip.78:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; MIBOX4 Build/PI) 2020-01-31 18:44:22.789 Info HttpServer: HTTP Response 200 to 91.163.xx.xx. Time: 1ms. http://my_server_ip.78:8096/emby/system/info/public?format=json 2020-01-31 18:44:22.822 Info HttpServer: HTTP GET http://my_server_ip.78:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; MIBOX4 Build/PI) 2020-01-31 18:44:22.823 Info HttpServer: HTTP Response 200 to 91.163.xx.xx. Time: 1ms. http://my_server_ip.78:8096/emby/system/info/public?format=json 2020-01-31 18:44:26.875 Info HttpServer: HTTP GET http://my_server_ip.78:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; MIBOX4 Build/PI) 2020-01-31 18:44:26.876 Info HttpServer: HTTP Response 200 to 91.163.xx.xx. Time: 1ms. http://my_server_ip.78:8096/emby/system/info/public?format=json 2020-01-31 18:44:26.920 Info HttpServer: HTTP GET http://my_server_ip.78:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; MIBOX4 Build/PI) 2020-01-31 18:44:26.921 Info HttpServer: HTTP Response 200 to 91.163.xx.xx. Time: 1ms. http://my_server_ip.78:8096/emby/system/info/public?format=json 2020-01-31 18:45:16.503 Info HttpServer: HTTP GET http://my_server_ip.78:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; MIBOX4 Build/PI) 2020-01-31 18:45:16.504 Info HttpServer: HTTP Response 200 to 91.163.xx.xx. Time: 1ms. http://my_server_ip.78:8096/emby/system/info/public?format=json
ebr 16338 Posted January 10, 2021 Posted January 10, 2021 This should be fixed in the current beta of the app. Thanks.
