dovedescent7 3 Posted January 30, 2020 Posted January 30, 2020 (edited) I don't know if its my IPTV provider but every single day when the wife goes to Emby for live TV, no guide data displays for some channels, for others it is simply incorrect. In other cases it seems an update in Emby requires a restart, and that is preventing happy live tv use to some extent, usually a channel wont load. The only way i can remedy this is to force Refresh Guide data in Live TV, then restart Emby. Which often will cut or break recordings doing so, but must be done. System- Windows 10 x64 Emby Server 4.3.1.0 Is it possible to create scheduled tasks to refresh live guide data more often or at least 1 or 2 times more per day? And also schedule Emby restarts? If so would someone please point me to how? This would make life happy again. Thank you. Edited January 30, 2020 by dovedescent7
Solution Luke 42216 Posted January 30, 2020 Solution Posted January 30, 2020 Is it possible to create scheduled tasks to refresh live guide data more often or at least 1 or 2 times more per day? Hi there, have you explored the server scheduled tasks section? 1
dovedescent7 3 Posted January 30, 2020 Author Posted January 30, 2020 Hi there, have you explored the server scheduled tasks section? Explored it to the extent of only using it thrice, only for backup config
dovedescent7 3 Posted January 30, 2020 Author Posted January 30, 2020 (edited) Apologies, i now see where i can schedule task to refresh live tv. Im sorry i missed this. I changed guide data to refresh every 24 to every 6 hours. I hope this will not interrupt or effect recordings. Can i also schedule restarts? I actually read you cannot schedule restarts. Edited January 30, 2020 by dovedescent7
dovedescent7 3 Posted January 30, 2020 Author Posted January 30, 2020 (edited) Hi there, have you explored the server scheduled tasks section? i figured this out. Could you please point me to where this section in the below picture is? I dont know the location, or how to get here. I saw in a post I found it, just took a little searching.thank you Edited January 30, 2020 by dovedescent7
Luke 42216 Posted January 30, 2020 Posted January 30, 2020 I think that is completely unrelated to what you were asking about.
