kpkimmel1983 1 Posted January 30, 2020 Posted January 30, 2020 hdhomerun extend has transcoding, its enabled in the emby options but i do not see where i can chose the quality/transcoding options, all i see are my servers video card transcoding options. How do i know its using my extend and not my pc?
Luke 42244 Posted January 30, 2020 Posted January 30, 2020 Hi, that's all you need to do. Emby will choose the best stream quality from the HDHR based on the quality settings of the Emby app you're playing from.
kpkimmel1983 1 Posted January 30, 2020 Author Posted January 30, 2020 Hi, that's all you need to do. Emby will choose the best stream quality from the HDHR based on the quality settings of the Emby app you're playing from. I would like to pick it so my recordings are smaller. Not just the quality of the stream.
Luke 42244 Posted February 1, 2020 Posted February 1, 2020 An option is possible for the future. Thanks.
