deadscope 0 Posted January 30, 2020 Posted January 30, 2020 so i keep getting remote errors saying im not connected when i am but its only when i try to invite friends to my connect the strangest thing is that it keeps going on and off so sometimes i can invite them then other times i cant its really strange its passing threw my firewall/antivirus because i can get the connect when im away from my home https://cdn.discordapp.com/attachments/473242777912868869/672286444449955870/Untitled.png
Luke 42216 Posted January 30, 2020 Posted January 30, 2020 Hi there, can you please attach the emby server log from when this happened? Thanks.
pwhodges 2028 Posted January 30, 2020 Posted January 30, 2020 Click "More Reply Options" next to the Post button. Note that after you've selected a file you have to attach it as a separate action. Paul
deadscope 0 Posted January 30, 2020 Author Posted January 30, 2020 tried it again this is the most recent
Luke 42216 Posted January 30, 2020 Posted January 30, 2020 Hi, all of the server's outgoing communications are failing. Most likely you have something blocking the outbound connections such as firewall, security software, or vpn. If you can remove this barrier then it should resolve itself.
deadscope 0 Posted January 30, 2020 Author Posted January 30, 2020 okay i guess ill have to search around
deadscope 0 Posted January 30, 2020 Author Posted January 30, 2020 turned everything off still not working
deadscope 0 Posted January 31, 2020 Author Posted January 31, 2020 firewall antvirus from windows sercruity also removed a vpn i did have
Luke 42216 Posted January 31, 2020 Posted January 31, 2020 I would check windows firewall to make sure there are no rules blocking emby server.
deadscope 0 Posted January 31, 2020 Author Posted January 31, 2020 i even made a new rule for outbound connections for emby but didnt change anything
Luke 42216 Posted February 1, 2020 Posted February 1, 2020 Nonetheless there will has to be something blocking the emby server process from making these connections. You could also try running the server as administrator and see how that compares.
