gmacman 3 Posted January 28, 2020 Posted January 28, 2020 I'd like to add home movies to be viewed as a library. I'm using Embuary skin on Emby for Kodi. My home movies are in a "home videos & photos" library on Emby.
Luke 42234 Posted January 28, 2020 Posted January 28, 2020 Hi, correct me if I'm wrong but Kodi doesn't support this, right? It might just have to be a regular movies library. But I'm not sure.
sualfred 677 Posted January 28, 2020 Posted January 28, 2020 Kodi has no library type for home videos. All you can do is to link a own menu item to the Emby addon node.
gmacman 3 Posted January 29, 2020 Author Posted January 29, 2020 Kodi has no library type for home videos. All you can do is to link a own menu item to the Emby addon node. Thanks. I kind of remember this now, something about syncing. Kind of a bummer, but thanks again I'll try that approach.
