thrillcat 14 Posted January 26, 2020 Posted January 26, 2020 In Emby, the aspect ratio seems to be simply representing the resolution aspect ratio instead of the actual film's ratio. Example: Apocalypse Now UHD is listed as 3840x2160 resolution, and 16:9 Aspect Ratio. However, if you go to IMDB and view the actual aspect ratio (or play the film), it's correctly reported as 2.39:1. For those of us with projectors and masking systems, having this information right there on the movie's title page is really nice, but it doesn't seem accurate. Could that information be pulled from IMDB instead of the file resolution? One step further, it would be REALLY cool if the aspect ratio could be added at the top of the movie page with the length and rating, etc. information. Perhaps have several fields the user could choose up to X number to display at the top. I love the "ends at" item, and the rating, viewer rating, etc., but could do without date added, etc. up there, and would prefer a couple other options. Thanks!
Happy2Play 9806 Posted January 26, 2020 Posted January 26, 2020 (edited) Sorry no information can come directly from IMDB do to the fact they do not have a free api. Every source/encode could be different so simply applying a arbitrary values I think would cause just as many problem. Date Added isn't going anywhere, lots of posts about it being gone right now in 4.3. It will be back in 4.4. Edited January 26, 2020 by Happy2Play
thrillcat 14 Posted January 26, 2020 Author Posted January 26, 2020 Again, a choice would be nice. Alllow each user to turn off or turn on up to, say 5 metadata items to include in that space. But back to aspect ratio, is there another database that could provide accurate info on AR? Sent from my iPhone using Tapatalk
Happy2Play 9806 Posted January 26, 2020 Posted January 26, 2020 My question would be why is it not showing the correct AR? Personally I would expect the media to be correct over any database.
thrillcat 14 Posted January 26, 2020 Author Posted January 26, 2020 I don’t know. This is an MKV rip of the new Rambo. This is the actual file playing. Definitely NOT 16:9. A quick sampling shows that every movie in my library reads as 16:9. Sent from my iPhone using Tapatalk
crusher11 1137 Posted January 26, 2020 Posted January 26, 2020 My question would be why is it not showing the correct AR? Personally I would expect the media to be correct over any database.Because Blu-Ray only supports 16:9, so movies of any other ratio have hard coded pillar or letter boxes.
Happy2Play 9806 Posted January 26, 2020 Posted January 26, 2020 Well all my Test media would appear to shows their proper AR. So is this a encoding issue?
Happy2Play 9806 Posted January 26, 2020 Posted January 26, 2020 (edited) 3840X2160 Is 16:9 3840x1608 is 2.39:1. Edited January 26, 2020 by Happy2Play
thrillcat 14 Posted January 26, 2020 Author Posted January 26, 2020 Well all my Test media would appear to shows their proper AR. So is this a encoding issue? Straight bluray rips using makemkv, so I don’t know? PLEX shows the same incorrect data. I’m not doing anything but rip, no transcoding. Sent from my iPhone using Tapatalk
thrillcat 14 Posted January 26, 2020 Author Posted January 26, 2020 Never mind. It looks like it might be a makemkv issue. Sent from my iPhone using Tapatalk
Luke 42216 Posted January 26, 2020 Posted January 26, 2020 The black padding is typically embedded into the video so that's why it would be different than what you see on Imdb.
crusher11 1137 Posted January 26, 2020 Posted January 26, 2020 Well all my Test media would appear to shows their proper AR. So is this a encoding issue? How are you getting your Test media? Blu-ray and UHD only support 16:9, DVD only supports 4:3 and 16:9. The only way to get any other resolution is to re-encode and remove the black bars.
sfatula 208 Posted January 26, 2020 Posted January 26, 2020 The only way to get any other resolution is to re-encode and remove the black bars. Exactly. When I Handbrake mine, I get correct aspect ratio as Handbrake removes the black bars.
thrillcat 14 Posted January 26, 2020 Author Posted January 26, 2020 Exactly. When I Handbrake mine, I get correct aspect ratio as Handbrake removes the black bars. So we must sacrifice quality to remove black bars. Which leads me back around to my original question. Is there a different source which would provide accurate aspect ratio information for the film, not the file? Blu-ray.com perhaps? Sent from my iPhone using Tapatalk
sfatula 208 Posted January 26, 2020 Posted January 26, 2020 So we must sacrifice quality to remove black bars. I don't sacrifice any perceivable (by me) quality, but, I was in no way suggesting you must or should do this. I was merely agreeing with crusher11 by pointing out if you do remove them, the ratio is correct. You've already lost quality as bluray is compressed.
crusher11 1137 Posted January 26, 2020 Posted January 26, 2020 That hypothetical original isn't relevant to anything, though, because it's unattainable. Compressing further to remove letter or pillarboxing is an entirely different matter. 2
sfatula 208 Posted January 26, 2020 Posted January 26, 2020 That hypothetical original isn't relevant to anything, though, because it's unattainable. Compressing further to remove letter or pillarboxing is an entirely different matter. You're not zipping a zip file. You are more accurately re-compressing. It is decompressed, adjusted, and re-compressed. You don't need to shrink the file, up to you based on your settings. But UHD takes a long time to process anyway, and it's a hassle. I just disagree with the notion you are losing something, other than time. If you have not done it from your first rip, then, too much work I am sure. I have more than a thousand movies, but, have processed every one of them. You can't get a movie aspect ratio from imdb or anywhere else, many movies come in different forms, for example IMAX versions which have their own aspect ratio. You could change the embedded title only and set the prefer embedded title option in Emby. This would allow you to put the aspect ratio in the title. But it's an interesting problem as I have a projector also and it is handy to know. Here's some posts from a while back related to this: https://emby.media/community/index.php?/topic/23735-aspect-ratio-using-original-aspect-not-file-aspect/
crusher11 1137 Posted January 26, 2020 Posted January 26, 2020 It is decompressed, adjusted, and re-compressed. You don't need to shrink the file, up to you based on your settings. This is entirely incorrect. You can't "decompress" it. That would require magically inventing all the data that was compressed out of the image during the disc's authoring stage. You then compress it again after processing it, and you will lose quality relative to the original even if you output at exactly the same file size. That's how compression works. 1
sfatula 208 Posted January 26, 2020 Posted January 26, 2020 (edited) Semantics. So, you are saying the video a played as is? Hardly. The already compressed (encoded) frames have to be decoded (you might say decompressed) and assembled to form a complete frame to send to the video display, or, edited to remove the black bars, call it what you want. I was not saying you get the original video. Obviously you do not. You get the best approximation of the original video, just as you do when you play it. But believe as you wish! I've provided 2 solutions to the OP problem. Edited January 26, 2020 by sfatula 1
sfatula 208 Posted January 26, 2020 Posted January 26, 2020 Everything you just said is wrong. No idea what you are trying to say? You are offering a solution to the OP? It is not incorrect. And it most certainly is not incorrect to say I can remove the black bars and that "I see" no quality loss, which is what I said. You can imagine you see the loss if you wish. Read up, this says in more words what I am saying with less, which wasn't the point of course. The point is to address the OP not worry about other things that do not matter. https://www.vcodex.com/hevc-an-introduction-to-high-efficiency-coding/ A video decoder decompresses the bitstream to create a sequence of decoded frames. A video decoder reverses the steps: Entropy decoding and extracting the elements of the coded sequence Rescaling and inverting the transform stage Predicting each unit and adding the prediction to the output of the inverse transform Reconstructing a decoded video image.
thrillcat 14 Posted January 26, 2020 Author Posted January 26, 2020 No idea what you are trying to say? You are offering a solution to the OP? It is not incorrect. And it most certainly is not incorrect to say I can remove the black bars and that "I see" no quality loss, which is what I said. You can imagine you see the loss if you wish. Read up, this says in more words what I am saying with less, which wasn't the point of course. The point is to address the OP not worry about other things that do not matter. https://www.vcodex.com/hevc-an-introduction-to-high-efficiency-coding/ A video decoder decompresses the bitstream to create a sequence of decoded frames. A video decoder reverses the steps: Entropy decoding and extracting the elements of the coded sequence Rescaling and inverting the transform stage Predicting each unit and adding the prediction to the output of the inverse transform Reconstructing a decoded video image. Everything he said is accurate. I do not plan on utilizing your “solution”, as it’s not a solution, it’s a compromise, and not one I’m willing to make, so your time may be better spent in other threads. The only feasible “solution” to this issue is locating an open source database to use instead of the video file itself to pull the film’s aspect ratio information. Sent from my iPhone using Tapatalk
sfatula 208 Posted January 26, 2020 Posted January 26, 2020 (edited) The other solution I proposed is adjusting the movie title, it's a one time effort along with the change to Emby setting. That wouldn't work for you? Seems pretty simple. How do you otherwise propose to get around movies that come out in different formats (same movie) with different aspect ratios? Consider this page: https://www.imdb.com/title/tt1477834/technical Edited January 26, 2020 by sfatula
Happy2Play 9806 Posted January 26, 2020 Posted January 26, 2020 Basically you want original material and FAKE the AR to something the physical media technically is not. Emby probes the media, so 3840X2160 is 16:9. 1
