Montellese 11 Posted January 25, 2020 Posted January 25, 2020 I'm trying to use the "MinDateLastSaved" and "MinDateLastSavedForUser" filters on the /Items endpoint. The former works perfectly fine but as soon as a specify the latter (with or without the former) I always get an HTTP 500 error code with the following response body: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. I then checked the Emby server logs and found the following: 2020-01-25 11:10:07.809 Info HttpServer: HTTP GET http://localhost:8097/emby/Items?MinDateLastSavedForUser=2020-01-20T00:00:00&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&IncludeItemTypes=Movie. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36 2020-01-25 11:10:07.811 Error HttpServer: Error processing request *** Error Report *** Version: 4.3.1.0 Command line: C:\Users\XXX\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/XXX/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Program data path: C:\Users\XXX\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\XXX\AppData\Roaming\Emby-Server\system SQLitePCL.pretty.SQLiteException: Error: no such column: RatingLastModified - select A.Id,A.Name,A.RunTimeTicks,A.guid,A.ParentId,A.Images from MediaItems A where type=@[member="type"] AND ParentId=@ParentId AND ((DateLastSaved not null and DateLastSaved>=@MinDateLastSavedForUser) or (RatingLastModified not null and RatingLastModified>=@MinDateLastSavedForUser) or (PlaystateLastModified not null and PlaystateLastModified>=@MinDateLastSavedForUser)) SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteDatabaseConnection.PrepareStatement(String sql, String& tail) at SQLitePCL.pretty.DatabaseConnection.PrepareStatement(IDatabaseConnection This, String sql) at Emby.Server.Implementations.Data.SqliteItemRepository.QueryItemsInTransaction[T](InternalItemsQuery query, IDatabaseConnection db, String[] columnsToSelect, Func`5 rowReaderFn, Boolean singleResult, String methodName) at Emby.Server.Implementations.Data.SqliteItemRepository.GetItems(InternalItemsQuery query) at Emby.Server.Implementations.Library.LibraryManager.GetItemsResult(InternalItemsQuery query) at MediaBrowser.Controller.Entities.Folder.GetItemsInternal(InternalItemsQuery query) at MediaBrowser.Controller.Entities.CollectionFolder.GetItemsInternal(InternalItemsQuery query) at MediaBrowser.Controller.Entities.Folder.GetItems(InternalItemsQuery query) at MediaBrowser.Api.UserLibrary.ItemsService.GetQueryResult(GetItems request, DtoOptions dtoOptions, User user) at MediaBrowser.Api.UserLibrary.ItemsService.GetItems(GetItems request) at MediaBrowser.Api.UserLibrary.ItemsService.Get(GetItems request) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: SQLitePCL.pretty.IStatement PrepareStatement(System.String, System.String ByRef) 2020-01-25 11:10:07.811 Info HttpServer: HTTP Response 500 to ::1. Time: 2ms. http://localhost:8097/emby/Items?MinDateLastSavedForUser=2020-01-20T00:00:00&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&IncludeItemTypes=Movie So it looks like the SQL query is trying to filter on the column "RatingLastModified" which doesn't exist. I tried both from my own code and with Swagger (the log above is from a Swagger request). PS: Would it be supported to combine "MinDateLastSaved" and "MinDateLastSavedForUser" in the same request or do I have to perform two separate requests? Thanks for your support.
Luke 42239 Posted January 25, 2020 Posted January 25, 2020 Hi, yes it would be supported to combine the params. I'll look into why that column might not be there. Thanks.
Montellese 11 Posted February 6, 2020 Author Posted February 6, 2020 For some unknown reason this seems to be working now. Maybe it was fixed by an update of the Emby server?
Luke 42239 Posted February 7, 2020 Posted February 7, 2020 That's strange but thanks for the feedback.
