Dodgy Bob 45 Posted June 27, 2021 Posted June 27, 2021 (edited) Hi @radeon Just confirming, the DLL needs to go in ./volume1/emby/plugins - yeah ?? Or is it in ./var/packages/EmbyServer/target/system/plugins ?? Kind regards, Dodgy Bob Edited June 27, 2021 by Dodgy Bob Add in other directory
Happy2Play 9814 Posted June 27, 2021 Posted June 27, 2021 20 minutes ago, Dodgy Bob said: Hi @radeon Just confirming, the DLL needs to go in ./volume1/emby/plugins - yeah ?? Or is it in ./var/packages/EmbyServer/target/system/plugins ?? Kind regards, Dodgy Bob It will go in the first "/volume1/emby/plugins" as the second gets replaces with every server update. 2
jan_axhell 4 Posted June 27, 2021 Posted June 27, 2021 Ok, finished, job took 2 hours 10 minutes, got 220 trailers out of 470 movies. Behavior: downloaded a bunch of trailers at optimal speed, then looong pause even for half an hour, then another bunch, then pause and so on. Quite slow, but not bad, it works.
radeon 760 Posted June 27, 2021 Posted June 27, 2021 Yup, that would be right. It has pauses built in to prevent slamming servers 2
Dodgy Bob 45 Posted June 27, 2021 Posted June 27, 2021 12 hours ago, Happy2Play said: It will go in the first "/volume1/emby/plugins" as the second gets replaces with every server update. Schweeet! Thanks @Happy2Play; that's where I had it, so all is good.
Sharmy 9 Posted June 28, 2021 Posted June 28, 2021 Confirming this version works well for me with 4.6.3.0. It is much faster than previous versions in my environment (Emby server on ReadyNAS 626X). 1
