rickgillyon 10 Posted January 23, 2020 Posted January 23, 2020 I have a single tuner in LiveTV (actually xteve exposing multiple sources) and I want to add two EPGs, Emby and xmltv. I want to use the xml for some channels, Emby data for others. The xmltv epg has matched every channel correctly, as expected. It's matched some on the Emby data, but not well. It seems to currently be picking the xmltv data for everything (because it's first in the list?). So what I want to do is assign the Emby data correctly, and for the channels where I want to use the Emby data, just deselect it in the xmltv lineup. But how do I do that? Clicking on the currently-selected channel here: has no effect. So how do i deselect a channel so that it will go on and use the next lineup? Also, it would be so much better if these items could be in some logical order.
Luke 42244 Posted January 23, 2020 Posted January 23, 2020 Hi, we plan to revamp this user interface in upcoming updates, but yes it is currently prioritized by the order. It sounds like you want the emby guide data to be first. 1
rickgillyon 10 Posted January 23, 2020 Author Posted January 23, 2020 Do I have to remove the xmltv provider and re-add to put it second? And this still doesn't really fix the problem: where the Emby provider has assigned a channel which it doesn't have, how do I un-assign it so it picks up the second provider?
Luke 42244 Posted January 23, 2020 Posted January 23, 2020 Yes remove and readd. Try using the mapping tool on the xml provider to pick the right one. I'm not sure that will correct the situation though but let's see what happens there. Thanks.
rickgillyon 10 Posted January 23, 2020 Author Posted January 23, 2020 Yeah, I've tried the mapping tool for quite some time, but there doesn't seem to be an option to select nothing. So it won't work, I can't get rid of the incorrect ones.
Q-Droid 1011 Posted January 23, 2020 Posted January 23, 2020 Can you go into the other guide source and pick the channel you want to override the auto selection? 1
rickgillyon 10 Posted January 23, 2020 Author Posted January 23, 2020 Yes, I can change the channel's source to another channel. But that still means it has data, so won't use the second source. I really need to be able to set it to nothing.
Spaceboy 2573 Posted January 23, 2020 Posted January 23, 2020 Yeah, I've tried the mapping tool for quite some time, but there doesn't seem to be an option to select nothing. So it won't work, I can't get rid of the incorrect ones.yeah it’s only been 2 or 3 years since that issue was pointed out. Hopefully soon 2
rickgillyon 10 Posted January 24, 2020 Author Posted January 24, 2020 I was hoping to find a json file somewhere I could edit, but I can't find one.
Q-Droid 1011 Posted January 24, 2020 Posted January 24, 2020 Yes, I can change the channel's source to another channel. But that still means it has data, so won't use the second source. I really need to be able to set it to nothing. Yeah, I tried a quick test and it looks like I can't override the 1st source by manually selecting a channel in the 2nd source. I have a split tuner config which might be the only way until unlinking a channel becomes an option. That or even more external EPG and channel manipulation. 1
dovedescent7 3 Posted March 31, 2020 Posted March 31, 2020 I have the sort of the same question except what i need to do is get EPG guide data for longer than 24 hours, because providers xmltv only offers 24 hours of guide data at a time. Would one do this in Xteve? If so , how?
Luke 42244 Posted March 31, 2020 Posted March 31, 2020 I have the sort of the same question except what i need to do is get EPG guide data for longer than 24 hours, because providers xmltv only offers 24 hours of guide data at a time. Would one do this in Xteve? If so , how? Re: https://emby.media/community/index.php?/topic/64414-using-xteve-with-emby/?p=864799
