Niklos 3 Posted January 22, 2020 Posted January 22, 2020 Hi guys. Now that I (well, you ^^) solved my problem of stuttering, I have another problem. Here it is. When Emby has some conversion to do, the movie is unplayable but whatever, and also, the NAS CPU goes to 100% because of some FFMPEG processus. If I stop the movie, those FFMEG process stay there. The only way I found to get rid of them is to restart my Emby container. So, right now, I put a scheduled task on my NAS that restart every night my PLEX docker but... That not optimal... Do you know anyways to kill those FFMPEG processus when I stop the movie ? Nb : My emby server is installed on a docker container that is on a Synology DS1819+.
Luke 42237 Posted January 22, 2020 Posted January 22, 2020 Hi there, can you please attach the emby server log? thanks.
Niklos 3 Posted January 22, 2020 Author Posted January 22, 2020 Hmm, sure... One day I'll be able to do my post correctly at the first try :-D. logs.tgz.gz
Luke 42237 Posted January 26, 2020 Posted January 26, 2020 You're trying to transcode 4K bluray content while also burning in subtitles on the fly. This will be a very intensive process even for a powerful server machine.
Luke 42237 Posted January 26, 2020 Posted January 26, 2020 If you turn off subtitles the CPU usage may come down a little, although even that's not guaranteed.
Niklos 3 Posted January 26, 2020 Author Posted January 26, 2020 Well, for some reason, if I kill the ffmpeg process, then turn off subtitles, and play the movie, I have no issue. It is not transcoding anymore. But the point is, why do I have to kill those ffmpeg processes ? Why don t they stop when I stop the movie ?
Luke 42237 Posted February 12, 2020 Posted February 12, 2020 @@Niklos Why don t they stop when I stop the movie ? They do stop. How exactly did you stop the movie?
Niklos 3 Posted February 13, 2020 Author Posted February 13, 2020 I press the "pause" button then turn of the TV or switch to some TV show 1
