moviepalace4K 30 Posted January 21, 2020 Posted January 21, 2020 Hi, the following problem arises with me: I can't sign up locally. The LAN address is displayed as the WAN ip address (46,192......). And the WAN address is displayed as the correct address (https://.....), only: the LAN address must actually be the WAN address (the https address points to 46.192...). The question now: how can I change the LAN address again to localhost:8096
chef 3811 Posted January 21, 2020 Posted January 21, 2020 (edited) Did you change settings under the network tab in the dashboard? Did you edit the addresses? Edited January 21, 2020 by chef
Luke 42216 Posted January 21, 2020 Posted January 21, 2020 Hi, where does it say that for the LAN address?
