EmbyLearner 3 Posted January 21, 2020 Posted January 21, 2020 Team, 1. Has anyone found success in getting Emby Theater to open and close using a standard ehome TV Remote? 2. Likewise with Cyberlink PowerDVD15? (or any version) Are there any command line arguments that help when using PowerDVD as an external player other than just {Path}?
Luke 42241 Posted January 21, 2020 Posted January 21, 2020 Hi, have you checked powerdvd documentation regarding their command line?
EmbyLearner 3 Posted January 21, 2020 Author Posted January 21, 2020 Yes no luck there. Was hoping someone has already accomplished the open/close Emby with TV remote or knew how to use the command line features in Emby to make cool stuff happen.
Luke 42241 Posted January 21, 2020 Posted January 21, 2020 accomplished the open/close Emby with TV remote If you're referring to the green button that is unfortunately more complicated than you might think and requires editing the windows registry to customize the function of the ehome button. @ might know something about that.
serpi 82 Posted January 21, 2020 Posted January 21, 2020 (edited) You can use the Advanced MCE Remote Mapper Tool to change the functions of the remote control buttons. I, for example, have the green button mapped to CTRL+ESCAPE, so the start menu opens when pressing the button. Then I have Emby (and Kodi) fixed in the Windows 10 start menu, so I can move to them with the remote and start it from there. Don't forget to backup the settings, as you have to restore them after each bigger Windows update. Here is also some info how to use this tool. It should also be able to add some hotkeys with third party tools, to directly start Emby or other programs, but I never needed this. Ciao, Alfred Edited January 21, 2020 by serpi
JMR 4 Posted January 31, 2020 Posted January 31, 2020 (edited) Been awhile but if you pin to task bar then make a key alt plus the location on task bar 1 or or mine is 3 then when you push that button emby will launch do same for power dvd Edited January 31, 2020 by JMR
