vdatanet 1619 Posted February 11, 2020 Posted February 11, 2020 It will need to do a full transcode to write it. Video tag is not correct. It's hev1 instead of hvc1. Apple TV native player transcodes because tag hvc1 is missing.
Luke 42239 Posted February 11, 2020 Posted February 11, 2020 Video tag is not correct. It's hev1 instead of hvc1. Apple TV native player transcodes because tag hvc1 is missing. can you post the media info from the web app?
vdatanet 1619 Posted February 12, 2020 Posted February 12, 2020 can you post the media info from the web app? @@softworkz Codec tag is hev1, then Apple TV transcodes video because it requires hvc1. Doing this, it direct plays: ffmpeg -i input.mkv -map 0:0 -map 0:1 -c:v copy -c:a copy -tag:v hvc1 output.mp4
softworkz 5133 Posted February 13, 2020 Posted February 13, 2020 @@vdatanet - I'm not sure about what situation you're talking here. Could you please show an ffmpeg log from Emby to which you think your suggestion should be applied to?
vdatanet 1619 Posted February 13, 2020 Posted February 13, 2020 (edited) @@vdatanet - I'm not sure about what situation you're talking here. Could you please show an ffmpeg log from Emby to which you think your suggestion should be applied to? @@softworkz I will try to summarize it: 1. As Apple TV does not support direct MKV playback, I want to repack all my HEVC HDR MKVs to MP4, to avoid H265 to H264 transcoding 2. There are many tools that do the job, but my server is headless and I prefer to run commands on the server side 3. I use a command similar to this one, depending on audio tracks: ffmpeg -i input.mkv -map 0:0 -map 0:1 -c:v copy -c:a copy -tag:v hvc1 output.mp4 This way Apple TV can direct play those MP4s, the key is: -tag:v hvc1, without that tag, video is transcoded when played on Apple TV 4. As I'm a bit lazy, I don't want to write those commands and I want to use Emby built-in conversion utility. 5. The problem is that tag is not written: 6. This is the command: >>>>> Legacy Command /opt/emby-server/bin/ffmpeg -re -f matroska -i file:"/media/4k/Star Wars Episodio 4 [4K UHDrip][2160p][HDR][AC3 5.1-DTS 5.1 Castellano-DTS 5.1-Ingles+Subs][ES-EN]/Star Wars Episodio 4 4Krip2160.www.pctnew.org.mkv" -map 0:0 -map 0:1 -map 0:2 -map 0:3 -sn -c:v:0 copy -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 aac -metadata:s:a:0 language=spa -disposition:a:0 default -ac:a:0 6 -ab:a:0 384000 -codec:a:1 copy -metadata:s:a:1 language=spa -disposition:a:1 none -codec:a:2 aac -metadata:s:a:2 language=eng -disposition:a:2 none -ac:a:2 6 -ab:a:2 384000 -y "/var/lib/emby/sync/6/14/04e7fd2e-258f-4108-ab47-8d942dfcef91.mp4" >>>>> Actual Command /opt/emby-server/bin/ffmpeg -loglevel +timing -y -print_graphs_file /var/lib/emby/logs/ffmpeg-remux-04e7fd2e-258f-4108-ab47-8d942dfcef91_1graph.txt -copyts -start_at_zero -f matroska,webm -re -c:v:0 hevc -i "/media/4k/Star Wars Episodio 4 [4K UHDrip][2160p][HDR][AC3 5.1-DTS 5.1 Castellano-DTS 5.1-Ingles+Subs][ES-EN]/Star Wars Episodio 4 4Krip2160.www.pctnew.org.mkv" -map 0:0 -map 0:1 -map 0:2 -map 0:3 -sn -c:v:0 copy -c:a:0 aac -ab:a:0 384000 -ac:a:0 6 -metadata:s:a:0 language=spa -disposition:a:0 default -c:a:1 copy -metadata:s:a:1 language=spa -disposition:a:1 0 -c:a:2 aac -ab:a:2 384000 -ac:a:2 6 -metadata:s:a:2 language=eng -disposition:a:2 0 -avoid_negative_ts disabled -f mp4 -map_metadata -1 -map_chapters -1 "/var/lib/emby/sync/6/14/04e7fd2e-258f-4108-ab47-8d942dfcef91.mp4" 7. Since version 4.4.0.13, a video tag is written, but it writes hev1 instead of hvc1. 8. Videos tagged as hev1 are transcoded when played on Apple TV My suggestion is to write hvc1 tag instead of hev1, if possible. Thanks! Edited February 13, 2020 by vdatanet 1
softworkz 5133 Posted February 13, 2020 Posted February 13, 2020 @@vdatanet - Thanks for explaining. I wasn't sure whether this is about playback or conversion and mkv or mp4. HEV1 and HVC1 are so-called FourCC tags. These are supported by MP4 containers but not MKV containers (these have their own 'Codec IDs'). I have already made a change in the latest beta to write an HVC1 tag instead of HEV1, when... ..the conversion feature is used and... ...the target container is MP4 and... ...the codec is HEVC I have tested and verified that this is working. But using the convert feature on 10bit HEVC normally causes transcoding and not remuxing, so I wonder how you managed to end up with the (remuxing) command line above? 2
vdatanet 1619 Posted February 13, 2020 Posted February 13, 2020 Selecting "Original quality" remuxes the file without reencoding video. 1
vdatanet 1619 Posted February 15, 2020 Posted February 15, 2020 @@vdatanet - Thanks for explaining. I wasn't sure whether this is about playback or conversion and mkv or mp4. HEV1 and HVC1 are so-called FourCC tags. These are supported by MP4 containers but not MKV containers (these have their own 'Codec IDs'). I have already made a change in the latest beta to write an HVC1 tag instead of HEV1, when... ..the conversion feature is used and... ...the target container is MP4 and... ...the codec is HEVC I have tested and verified that this is working. But using the convert feature on 10bit HEVC normally causes transcoding and not remuxing, so I wonder how you managed to end up with the (remuxing) command line above? @@softworkz - With server version .14 tag hev1 is still written instead of hvc1.
vdatanet 1619 Posted February 18, 2020 Posted February 18, 2020 Using beta version 4.4.0.15 hvc1 tag is written. Thanks! 1
Luke 42239 Posted February 18, 2020 Posted February 18, 2020 Using beta version 4.4.0.15 hvc1 tag is written. Thanks! Thanks for confirming.
Luke 42239 Posted October 22, 2025 Posted October 22, 2025 Hi, HDR playback has been improved in Emby for Apple TV 2.0.1. Thanks !
