DancingMan 1 Posted January 19, 2020 Posted January 19, 2020 I recently moved my Emby server from a Windows 10 box to an xubuntu 19.10 box.the both have the latest stable branch and the same plugins (including auto box sets). My new server isn't generating any box sets... Even if I click "refresh box sets" in the auto box sets plugin. I'm not home right ow so I can't generate any logs right now, but I was wondering if anyone has experienced this? Thanks.
Luke 42246 Posted January 19, 2020 Posted January 19, 2020 Hi there, have you explored the auto boxsets wiki to learn what is required in order for them to be created? https://github.com/MediaBrowser/Wiki/wiki/AutoBoxSets 1
DancingMan 1 Posted January 19, 2020 Author Posted January 19, 2020 It worked fine on my windows server, so the TmdbCollectionId should be in the data (but I'll check when I can). I used the server configuration backup plugin to backup and then restore on the Linux box. Then I adjusted the paths on the Linux server to nfs. I've scanned the libraries, and I've added movies and the Metadata is saved with the media (so write permissions should be good).
Luke 42246 Posted January 19, 2020 Posted January 19, 2020 so the TmdbCollectionId should be in the data (but I'll check when I can). Yes that would be a good place to start.
DancingMan 1 Posted January 20, 2020 Author Posted January 20, 2020 (edited) It finally generated box sets. TmdbCollectionId was in the data, and scanning the library and doing a refresh Metadata (find missing data) didn't help... It wasn't until I refreshed all Metadata and replaced all images that the box sets started working. Edited January 20, 2020 by DancingMan
