icerider 0 Posted January 18, 2020 Posted January 18, 2020 Hi. I'm new into streaming Live TV DVR. Have a new setup with HDHomerun Extend and a newly bought Nvida Shield PRO. I tried PLEX and PLEX PASS as DVR server but realised that casting via Cromecast was not supported. PLEX could see all the channels including guide data I have now installed Emby and tried to configure it correctly. It does find my HDHomerun and all the channels. But i see no channel data. Under configuration(region Denmark) i have the choice to select Schedules direct or XMLTV. Schedules direct is not free. Do i need to by a extra subscription to get the channel data? or do i have to manually import an XML file to my Shield. Next if i try to cast to any of my TV's i get the message ready to cast and then a black TV screen. In earlier strings ind this forum i can see that that this isn't a new issue. Does anyone have a solution to my problems. Thanks.
ebr 16332 Posted January 18, 2020 Posted January 18, 2020 Hi. If you are outside of the regions we provide guide data for (US, Canada, UK) then, yes, you will need an external source of some kind. Please ask your Chromecasting question in the forum section for the app you are casting from and I'm sure we can help you with that. Thanks.
Luke 42237 Posted January 18, 2020 Posted January 18, 2020 This may help you with an xmltv source for Denmark: https://www.mythtv.org/wiki/XMLTV#Denmark
