Duffyx 25 Posted January 18, 2020 Posted January 18, 2020 (edited) Hi, In the last update I have a problem getting musicbrainz to download any artwork. The log is in attachments, seem a regression with mono to obtain a trust anchor for HTTPS? Regards, Dries log.txt Edited January 18, 2020 by Duffyx
Duffyx 25 Posted January 18, 2020 Author Posted January 18, 2020 Hmm I posted too soon ..., title would better be: "Error App: Error in MusicBrainz"
Luke 42238 Posted January 18, 2020 Posted January 18, 2020 Hi, we changed our musicbrainz mirror and for some reason FreeBSD is not accepting our SSL certificate. It could be that your certificate store does not trust it. In any case we'll look at forcing it for the next release. Thanks.
Duffyx 25 Posted January 28, 2020 Author Posted January 28, 2020 On FreeBSD we use the Firefox NSS root CA's. The following errors I get when trying to reach it manually from my system: [/usr/home/dries]$ fetch https://musicbrainz.emby.tv Certificate verification failed for /OU=Domain Control Validated/OU=PositiveSSL Wildcard/CN=*.emby.tv 34370523136:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: fetch: https://musicbrainz.emby.tv:Authentication error When I use Chrome on Windows 10 I can surf to it perfectly fine. Checking with SSL labs it should be trusted by Mozilla ... It seems the full chain cert is not served to clients (chain incomplete) & wrong HSTS header policy. Not sure if any of those have anything to do with it. Forcing it is one solution although not the correct one IMO. 1
Luke 42238 Posted January 30, 2020 Posted January 30, 2020 Yes we are looking into the certificate chain as well. Thanks for the feedback. 1
Duffyx 25 Posted February 7, 2020 Author Posted February 7, 2020 Seems good! Logs are clean and metadata is being downloaded for music. Thanks!
