trmb 2 Posted January 16, 2020 Posted January 16, 2020 (edited) Does anyone have irTrans working in linux for Emby Theater? I have a living room htpc running emby server in a Zalman HD160 case that has IrTrans receiver remote built into it. IrTrans with the MCE remote has worked well for me in Windows 7 Media Center and Emby Media Center Classic, but it is time to retire Win7 MCE. IrTrans and the remote does work for Emby Theater for Windows, but I'm trying to avoid Win 10 bloat and its random rebooting for forced upgrades. So I'd like to shift to a Ubuntu htpc using Emby Theater to replace MCE in the living room, then possibly Docker after I get things debugged. Biggest stumbling block so far has been getting irTrans and the MCE remote to work in Emby Theater for linux. I downloaded the linux IrTrans drivers and installed them. Irtrans' irserver works in test mode, recognizing the MCE remote button presses. I then installed it as a service and made sure it starts. I configured a apps.cfg [*] section to translate buttons to keypress for emby-theater, as I had done in windows and as suggested elsewhere here. However, it does not work; no keypresses seem to be forwarded to the emby-server process [of which there are many]. File permissions on apps.cfg are set to a+r, so that shouldn't be the issue. Any chance anyone can help solve this Ubuntu/irTrans/remote issue? Edited January 16, 2020 by trmb
Luke 42246 Posted January 17, 2020 Posted January 17, 2020 Hi, that might be tricky as the process that should receive the keypress is actually the electron process that theater launches. But why do you have to configure the process? Can't it just send it to whatever window currently has focus?
trmb 2 Posted January 17, 2020 Author Posted January 17, 2020 (edited) I am attempting to use irtrans to forward the keypresses to any process [App]* but apparently the button presses [which are recognized] aren't being translated into keypresses at all. What I am wondering is if I am missing something about how irtrans should be generating keypresses in ubuntu, ie "Do I need to be configuring LIRC somehow?" Details: I run irserver as follows: sudo /usr/local/irtrans/irserver64 -loglevel 4 -codedump -debug_code -daemon /dev/ttyUSB0 The irserver.log looks like this: Init Server Socket done IRServer64 Version 6.10.23 Init Events done Opening Device: /dev/ttyUSB0 IRTRans Send Done: 1 Name : Version: D5.03.08 FW SNo : 15768 Capab : Power On; FW Cap : 0x3c8019 USB SNo: Node : /dev/ttyUSB0 Init communication ... [ 0]: D5.03.08 SN: 15768 Chdir to DB OK Read routing OK Read Switches OK Open DIR: 0 Get Dirent: 272 Remote mce-keyboard compiled: 1 Timings - 77 Commands Remote mediacenter compiled: 1 Timings - 49 Commands Remote mce-mouse compiled: 1 Timings - 1 Commands Get Dirent: 0 Total: 3 Remotes - 3 Timings - 127 Commands - 0 Calib. Commands 0 Togglec. - 0 CCF Data - 0 CCF RAW - 0 CCF Error IRTRans Send status: 0 - 0 SEQ:122 TO:500 IRTRans Send status: 1 - 69 SEQ:122 TO:500 IRTRans Send Done: 3 IRTRans Send Done: 1 Select Return: 1 [0.0] up mediacenter Select Return: 1 [0.0] down mediacenter Select Return: 1 [0.0] left mediacenter Select Return: 1 [0.0] 2 mediacenter Select Return: 1 [0.0] 3 mediacenter Select Return: 1 [0.0] 6 mediacenter Select Return: 1 [0.0] 9 mediacenter Select Return: 1 [0.0] 5 mediacenter Select Return: 0 So, I can see that my remote [.rem] files are being read and the button presses are understood by irtrans. What I don't have working or understand is the next step, getting those button presses translated into keypresses. On Windows this is configured by the apps.cfg file--and apparently for linux too looking into the kodi/xmbc info in the sample linux apps.cfg. Here is my apps.cfg file: [APP]* [ACTIVE] [TYPE]KEY [REMOTE]mediacenter [COMMANDS] 1 [KEY]1 2 [KEY]2[KEY]a[KEY]b[KEY]c 3 [KEY]3[KEY]d[KEY]e[KEY]f 4 [KEY]4[KEY]g[KEY]h[KEY]i 5 [KEY]5[KEY]j[KEY]k[KEY]l 6 [KEY]6[KEY]m[KEY]n[KEY]o 7 [KEY]7[KEY]p[KEY]q[KEY]r[KEY]s 8 [KEY]8[KEY]t[KEY]u[KEY]v 9 [KEY]9[KEY]w[KEY]x[KEY]y[KEY]z 0 [KEY]0[KEY]\SPACE OK [KEY]\ENTER LEFT [KEY]\LEFT RIGHT [KEY]\RIGHT DOWN [KEY]\DOWN UP [KEY]\UP BACK [KEY]\BACKSPACE PLAY [KEY]\CTRL\SHIFTP STOP [KEY]\CTRL\SHIFTS INFO [KEY]\CTRLD EHOME [KEY]\HOME REC [KEY] PAUSE [KEY]\CTRLP NEXT [KEY]\CTRL\SHIFTF PREV [KEY]\CTRL\SHIFTB FWD [KEY] REW [KEY] MUTE [KEY]\F8 RECTV [KEY] EPG [KEY] LIVETV [KEY] DVDMENU [KEY] CLEAR [KEY]\BACKSPACE TELETEXT [KEY] ENTER [KEY]\ENTER RED [KEY]\ALT1 GREEN [KEY]\ALT\SHIFT1 YELLOW [KEY]\ALT\CTRL\SHIFT1 BLUE [KEY]\ALT\CTRL2 [END-COMMANDS] [END-APP] [APP]* [ACTIVE] [TYPE]MOUSE [REMOTE]mce-mouse [END-APP] [APP]* [ACTIVE] [TYPE]KEYBOARD [REMOTE]mce-keyboard_v0 [END-APP] That's a simplified version of the same apps.cfg I use successfully in win 7 for emby-theater. What I am wondering is if I am missing something about how irtrans should be generating keypresses in ubuntu, ie "Do I need to be configuring LIRC somehow?" Edited January 18, 2020 by trmb
Luke 42246 Posted January 18, 2020 Posted January 18, 2020 @@KRA @@TrainAss @@mediaGuy @@SHSPVR @@xnappo May have some lirc tips.
SHSPVR 125 Posted January 20, 2020 Posted January 20, 2020 Sorry I never used irTrans and as for Lirc that I been under SageTV with USB-UIRT or Hauppauge IR but with Emby with my Phone a Unified Remote and it been some being that Emby Theater had issuse with playback
