gillmacca01 220 Posted January 16, 2020 Posted January 16, 2020 I'm having problems getting Emby to recognise multi-episodes properly (more than 1 episode per video file). I am running the latest beta version. I have tried removing the files (including nfo's), rescan library, and have tried re-adding manually and via 'auto organise' plugin, but the video files are always displayed with the filename (Show name - 1x01-x02 - episodes names) and because or this, no episode synopsis are downloaded. This may be related to the issue: I have compared the nfo file with single episode nfo files, and notice that the multi-episode nfo's are not showing season/episode numbers
pwhodges 2028 Posted January 16, 2020 Posted January 16, 2020 (edited) Although the naming convention you've used is shown in the article on naming (though with two digits for the season), I wonder if there's an issue with it. Certainly I have no problem with s01e01-e02 which works perfectly, so I guess you could try that just to see. (I don't use .nfo files, so I can't comment on that part) Paul Edited January 16, 2020 by pwhodges
gillmacca01 220 Posted January 16, 2020 Author Posted January 16, 2020 Tried your naming convention, and still getting the same results
pwhodges 2028 Posted January 16, 2020 Posted January 16, 2020 (edited) Ah well, it was just a thought... Better just wait for the devs, I guess. But I suppose you could check that the show name is identical in the directory name, and that you are using season sub-folders, as those both seem to make identification more reliable. Paul Edited January 16, 2020 by pwhodges
gillmacca01 220 Posted January 16, 2020 Author Posted January 16, 2020 I've partly resolved it. Using the info in the nfo's file from this post: https://emby.media/community/index.php?/topic/78937-multi-episode-file-not-registering-second-episode/, the episodes are displaying correctly, but episode synopsis still isn't being added (refreshed missing metadata, and did a library scan)
CBers 7546 Posted January 16, 2020 Posted January 16, 2020 I have named my multi-episodes as: "Show name - 9x01x02.mkv" Works for me.
Luke 42216 Posted January 16, 2020 Posted January 16, 2020 Yes please go over a complete example. Thanks.
gillmacca01 220 Posted January 17, 2020 Author Posted January 17, 2020 (edited) Added season 1 and episode 1 to the metadata editor, but is showing episode 2 as missing (did a library scan). I have filed in the synopsis manually as it wasn't retrieved Nfo file: <?xml version="1.0" encoding="utf-8" standalone="yes"?> <episodedetails> <plot>A man infected with a deadly virus boards Quantum Airlines flight 66 in Frankfurt, Germany. The US government must stop the plane before it lands at JFK International Airport</plot> <outline /> <lockdata>false</lockdata> <dateadded>2009-10-24 19:09:00</dateadded> <title>Episode 1, Episode 2</title> <director>Eric Laneuville</director> <rating>6.3</rating> <year>1996</year> <imdbid>tt5845148</imdbid> <tvdbid>6640422</tvdbid> <runtime>177</runtime> <genre>Action</genre> <genre>Drama</genre> <genre>Thriller</genre> <art> <poster>/share/CACHEDEV4_DATA/TV/TV/Pandora's Clock/Season 1/Pandora's Clock - 1x01-x02 - Episode 1, Episode 2-thumb.jpg</poster> </art> <episode>1</episode> <episodenumberend>2</episodenumberend> <season>1</season> <aired>1996-11-10</aired> <fileinfo> <streamdetails> <video> <codec>mpeg4</codec> <micodec>mpeg4</micodec> <bitrate>740111</bitrate> <width>720</width> <height>480</height> <aspect>4:3</aspect> <aspectratio>4:3</aspectratio> <framerate>29.97003</framerate> <scantype>progressive</scantype> <default>False</default> <forced>False</forced> <duration>177</duration> <durationinseconds>10623</durationinseconds> </video> <audio> <codec>mp3</codec> <micodec>mp3</micodec> <bitrate>320000</bitrate> <scantype>progressive</scantype> <channels>2</channels> <samplingrate>48000</samplingrate> <default>False</default> <forced>False</forced> </audio> </streamdetails> </fileinfo> </episodedetails> Edited January 17, 2020 by gillmacca01
Luke 42216 Posted January 17, 2020 Posted January 17, 2020 Try turning off the missing episodes feature in your library settings, then run a library scan.
gillmacca01 220 Posted January 17, 2020 Author Posted January 17, 2020 Done that, but it's still displaying missing episode
