Scott310 137 Posted January 16, 2020 Posted January 16, 2020 (edited) Hey guys, just a quick dumb question. I was moving some of the paths to a new drive and everything scanned and rebuilt just fine but for some odd reason the collections thumbnail is not rebuilding the mosaic of titles on the thumbnail. Its probably something stupid but I can't seem to figure out why. I even put the metadata back where it used to be to see if that would cause it to rebuild but nothing. I know the collection data is stored on the C: drive but I made no changes at all to the C: drive. Any suggestions? Thanks in advance. Edited January 16, 2020 by Scott310
Luke 42197 Posted January 16, 2020 Posted January 16, 2020 You'll need to do this process here: https://github.com/MediaBrowser/Wiki/wiki/Collections-%E2%80%93-Manual-Migration
Scott310 137 Posted January 16, 2020 Author Posted January 16, 2020 Sorry I'm confused. I did not move any libraries. I did not move the Metadata folder. My collections are still there with their Metadata. I only moved the Cache Path to another drive. The only issue I have is the thumbnail for collection is blank.
Luke 42197 Posted January 16, 2020 Posted January 16, 2020 If you click on it, do you see Collections?
Scott310 137 Posted January 16, 2020 Author Posted January 16, 2020 Yes I do. Everything is still there. Just the thumbnail is blank
Scott310 137 Posted January 16, 2020 Author Posted January 16, 2020 Any help on this? Sorry it's just annoying that I can't figure out why it's not rebuilding the thumbnail.
Luke 42197 Posted January 17, 2020 Posted January 17, 2020 You could try refreshing metadata on the Collections library.
Scott310 137 Posted January 17, 2020 Author Posted January 17, 2020 I think I may have found the problem. The drive that the metadata path is on is starting to fail and needs to be replaced. If I can't move all the metadata to the new drive before it dies can I create a new path on a new drive and will it re-download all the metadata onto the new drive during a scan?
Luke 42197 Posted January 17, 2020 Posted January 17, 2020 No it will just recognize that the current metadata is gone. You have to specifically refresh metadata.
Scott310 137 Posted January 17, 2020 Author Posted January 17, 2020 But I can just do that at the parent level if the library right? I don't have to do that individually for each movie I hope. Lol
Scott310 137 Posted January 19, 2020 Author Posted January 19, 2020 Sorry to keep asking about something so trivial but it is really bothering me that I can't figure it out. I am about ready to re-scan my entire library over a silly thumbnail LOL. I moved the metadata path to a new drive and refreshed. Everything downloaded great and the library is back to exactly the way it was with only one exception, the collections thumbnail is still blank. It must have something to do with the fact that the collections are on the C: drive and all of the other data is stored somewhere else. When I click on collections everything shows up as it should. But for some strange reason the thumbnail is not populating with movies from my collections. I am beating my head against a wall here...
Luke 42197 Posted January 19, 2020 Posted January 19, 2020 Try adding a new collection using the web interface. Then run a library scan.
Solution Luke 42197 Posted January 19, 2020 Solution Posted January 19, 2020 Try removing the collections library from library setup, then add a new collection and run a library scan. 1
sunnyg 0 Posted December 22, 2021 Posted December 22, 2021 Hi, I know this is a old post but I have the same issue, I had to install a fresh installation of emby on linux, due to the MB on the original install failing. I was able to perform the installation, and import the last backup that had been done, after the restoration of the backup the collections has no thumbnails: However selecting it does show the collections: However there is no option to refesh the data: even at library level: I am using emby sever 4.6.7.0, how can i perforrm a refresh or have the current collection deleted and rebuilt ? thanks in advance
Happy2Play 9802 Posted December 22, 2021 Posted December 22, 2021 43 minutes ago, sunnyg said: Hi, I know this is a old post but I have the same issue, I had to install a fresh installation of emby on linux, due to the MB on the original install failing. I was able to perform the installation, and import the last backup that had been done, after the restoration of the backup the collections has no thumbnails: However selecting it does show the collections: However there is no option to refesh the data: even at library level: I am using emby sever 4.6.7.0, how can i perforrm a refresh or have the current collection deleted and rebuilt ? thanks in advance Please post a server log after a Library scan.
sunnyg 0 Posted December 23, 2021 Posted December 23, 2021 16 hours ago, Happy2Play said: Please post a server log after a Library scan. Attached is the server log at debug, i stopped and cleared the logs, then started emby and ran the scan library before capturing the logs. embyserver.txt
sunnyg 0 Posted December 23, 2021 Posted December 23, 2021 2 hours ago, sunnyg said: Attached is the server log at debug, i stopped and cleared the logs, then started emby and ran the scan library before capturing the logs. embyserver.txt 152.08 kB · 0 downloads OK managed to resolve the issue, looks like the folder /var/lib/emby/data/collections did not get created automatically after the reinstall and restore from the backup file, manually creating it and running the scan library again seems to have resolved the thumbnails.. Maybe the startup code could be amended to create the folder if it doesn't exist..
