jang430 10 Posted January 15, 2020 Posted January 15, 2020 Hi. Installed Emby server docker app on Unraid. I have the processor that is capable of 10-bit hevc transcoding. My cpu works at 100% though during streaming from kodi. I have emby set at advanced in settings/ transcoding. I can see vaapi on h264, h265. Any suggestions?
Luke 42216 Posted January 15, 2020 Posted January 15, 2020 Hi there @@jang430, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks.
jang430 10 Posted January 16, 2020 Author Posted January 16, 2020 I hope this is it. I am trying to achieve h265 playback, using my Intel Celeron G3930 processor. ffmpeg-transcode-5748ee62-3e43-49ff-9d9b-3df23f46b44c_1.txt
Luke 42216 Posted January 16, 2020 Posted January 16, 2020 @@jang430, have you verified that it supports decoding hevc? Have you checked out our hardware acceleration setup guide?
jang430 10 Posted January 16, 2020 Author Posted January 16, 2020 I am using Unraid. I assume I should be looking for Intel Quicksync. Since it's not available as an option, I'm using Vaapi
Luke 42216 Posted January 16, 2020 Posted January 16, 2020 Can you attach the emby server log as well? Also can you update to Emby Server 4.3.1? Thanks.
jang430 10 Posted January 16, 2020 Author Posted January 16, 2020 sure, will do this as soon as I get access to lit later.
jang430 10 Posted January 16, 2020 Author Posted January 16, 2020 Checked for updates in apps page on my Unraid, it shows my container is up to date. Though in Emby settings, it does show there's a newer version available. I'm afraid to upgrade the emby server for fear it may break the whole emby docker container. embyserver.txt
DoeBoye 1 Posted January 22, 2020 Posted January 22, 2020 Hi Jang430, Even though Kaby Lake cpus supports h265 decoding, I think you're asking too much of a dual core CPU to run unraid, whatever other plugins/dockers you have, as well as decode and stream h265 content. Have you looked at getting a dedicated nVidia card and using the nVidia Unraid Plugin? It works really well and frees up your cpu to take care of the rest of the unraid tasks. Here's a link to the nvidia matrix that shows what cards support h265 decoding: https://developer.nvidia.com/video-encode-decode-gpu-support-matrix
