kumzrocks 1 Posted January 14, 2020 Posted January 14, 2020 Hi All Thanks a lot for enabling it for android started working flawlessly from day 1. I have just 1 small issue while deleting a media. I have set up server in android box and also connected to external storage. I can read and play contents from this storage but when i try to delete it gives error "There was an error deleting the item from Emby Server. Please check that Emby Server has write access to the media folder and try again." I have checked the permission of the user in emby server it has the permission to delete folders Also check in android box with Emby app permission it has the same permission as a FTP server which i running i can access the FTP server via file browser and delete connect in other devices Please find below the logs i found after deleting Android version is 8.1 Box Model is H96 Max + rk3328 2020-01-14 22:50:25.256 Info HttpServer: HTTP DELETE http://192.168.1.2:8096/emby/Items/3253. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.117 Safari/537.36 2020-01-14 22:50:25.394 Info App: Removing item from database, Type: Movie, Name: Drishyam, Path: /storage/9AF2BF43F2BF2285/kumz data/others_col_mov/Drishyam.mkv, Id: 32532020-01-14 22:50:25.394 Info App: Deleting path /storage/emulated/0/Android/data/com.emby.embyserver/files/metadata/library/b4/b4f809d7af3ceea667ccc7ec0e25993e2020-01-14 22:50:25.399 Info App: Deleting path /storage/9AF2BF43F2BF2285/kumz data/others_col_mov/Drishyam.mkv2020-01-14 22:50:25.404 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.0.6 Command line: /data/app/com.emby.embyserver-_PINun7Ob5gNnDxAYXd78A==/base.apk Operating system: Unix 4.4.120.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Runtime: file:///mscorlib.dll System.Environment.Version: 4.0.50524.0 Processor count: 4 Program data path: /storage/emulated/0/Android/data/com.emby.embyserver/files Application directory: /data/user/0/com.emby.embyserver Mono: 6.6.0 (2019-08/e1ef774391d) Android Version: 8.1.0-REL - Base: - SDK: OMr1 Build ID: OPM6.171019.030.B1 - Incremental: 053034 Patch-Level: 2018-07-05 Fingerprint: Android/rk3328/rk3328:8.1.0/OPM6.171019.030.B1/053034:user/release-keys Model: H96 Max+ - rockchip/Android Hardware: rk3328/rk3328/rk30board/rk30sdk SupportedAbis: arm64-v8a, armeabi-v7a, armeabi System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/storage/9AF2BF43F2BF2285/kumz data/others_col_mov/Drishyam.mkv' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.FileSystem.DeleteFile (System.String fullPath) [0x0006d] in <b7bb5f3538424ec1927304809f832185>:0 at System.IO.File.Delete (System.String path) [0x00014] in <b7bb5f3538424ec1927304809f832185>:0 at Emby.Server.Implementations.IO.ManagedFileSystem.DeleteFileInternal (System.String path, System.Boolean sendToRecycleBin) [0x00000] in <35383502c6e541e18437747c81175cb9>:0 at Emby.Server.Implementations.IO.ManagedFileSystem.DeleteFile (System.String path, System.Boolean sendToRecycleBin) [0x00024] in <35383502c6e541e18437747c81175cb9>:0 at Emby.Server.Implementations.Library.LibraryManager.DeleteItem (MediaBrowser.Controller.Entities.BaseItem item, MediaBrowser.Controller.Library.DeleteOptions options, MediaBrowser.Controller.Entities.BaseItem parent, System.Boolean notifyParentItem) [0x00223] in <35383502c6e541e18437747c81175cb9>:0 at Emby.Server.Implementations.Library.LibraryManager.DeleteItem (MediaBrowser.Controller.Entities.BaseItem item, MediaBrowser.Controller.Library.DeleteOptions options, System.Boolean notifyParentItem) [0x0001f] in <35383502c6e541e18437747c81175cb9>:0 at MediaBrowser.Api.Library.LibraryService.Delete (MediaBrowser.Api.Library.DeleteItems request) [0x00099] in <f28ad1a682514afd90f07da8ebb51b31>:0 at MediaBrowser.Api.Library.LibraryService.Delete (MediaBrowser.Api.Library.DeleteItem request) [0x00012] in <f28ad1a682514afd90f07da8ebb51b31>:0 at (wrapper dynamic-method) System.Object.lambda_method(System.Runtime.CompilerServices.Closure,object,object) at Emby.Server.Implementations.Services.ServiceController+<>c__DisplayClass6_0.<VoidActionDelegate>b__0 (System.Object service, System.Object request) [0x00000] in <35383502c6e541e18437747c81175cb9>:0 at Emby.Server.Implementations.Services.ServiceController.Execute (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, System.Object requestDto, MediaBrowser.Model.Services.IRequest req) [0x00073] in <35383502c6e541e18437747c81175cb9>:0 at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync (Emby.Server.Implementations.HttpServer.HttpListenerHost appHost, MediaBrowser.Model.Services.IRequest httpReq, MediaBrowser.Model.Services.IResponse httpRes, Emby.Server.Implementations.Services.RestPath restPath, System.String responseContentType, System.Threading.CancellationToken cancellationToken) [0x00168] in <35383502c6e541e18437747c81175cb9>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler (MediaBrowser.Model.Services.IRequest httpReq, System.ReadOnlyMemory`1[T] urlString, System.ReadOnlyMemory`1[T] localPath, System.Threading.CancellationToken cancellationToken) [0x00b48] in <35383502c6e541e18437747c81175cb9>:0 Source: mscorlib TargetSite: Void Throw() InnerException: System.IO.IOException: Permission denied Source: TargetSite:
Luke 42238 Posted January 14, 2020 Posted January 14, 2020 Hi, the server doesn't have permission to delete the files. If you can resolve this then the delete feature should work. Please let me know if this helps. Thanks.
kumzrocks 1 Posted January 15, 2020 Author Posted January 15, 2020 Hi @@Luke I checked the permission it has read and write permission settings. I tried with options within emby server app there is no option to give permission to path. Any idea how to give the permission? When I launched the server it asked the permission to read and write I gave permission. As far Android 8.1 I don't have option to give permission unless the application is asking far. Like when I started FTP it asked for giving permission for write access for path but I didn't get any options from emby server
Luke 42238 Posted January 15, 2020 Posted January 15, 2020 That's not something you set within emby server, it's something you do on the Android device. The emby server application is what needs delete permissions.
kumzrocks 1 Posted January 15, 2020 Author Posted January 15, 2020 @@Luke thanks for quick response. I was also sure it was in Android just couldn't figure out how to give the access to the storage there is no option in Android settings. Also I googled around if there is way nothing seems to work.
softworkz 5133 Posted January 15, 2020 Posted January 15, 2020 (edited) External storage on Android is a beast of its own. Sometimes, files need to be in a special folder for the app to have full access. This conversation https://emby.media/community/index.php?/topic/81185-accessing-microsd-card-usb-otg-with-emby/ might be of help. Edited January 15, 2020 by softworkz
