django58 0 Posted January 10, 2020 Posted January 10, 2020 Hi, Is this setting always available please ?
Luke 42216 Posted January 10, 2020 Posted January 10, 2020 Hi, Is this setting always available please ? Hi, yes it's in our Android TV app. Does that answer your question?
django58 0 Posted January 10, 2020 Author Posted January 10, 2020 Actually it's to cast on my Chromecast..
django58 0 Posted January 12, 2020 Author Posted January 12, 2020 Most of my movies or TV shows are 5.1 audio but Chromecast seems to not support it... And I have different audio codec... aac, ac3, mp3... Only 2.0 stereo works. I think that Emby (or Plex) don't have the capability to convert 5.1 surround to 2.0 stereo yet..
Luke 42216 Posted January 13, 2020 Posted January 13, 2020 So you're saying it's direct playing and you want it to be converted?
django58 0 Posted January 14, 2020 Author Posted January 14, 2020 Maybe.. Actually, I don't really know. How can I get my movies converted ?
Guest asrequested Posted January 14, 2020 Posted January 14, 2020 In your user settings in the server, try disabling 'allow audio playback that requires transcoding', and test playing your media, again. This will test if your Chromecast actually supports the audio. If it does, it will play correctly.
Luke 42216 Posted January 14, 2020 Posted January 14, 2020 No, don't do that, it's already direct playing. Can you please go over an example? Please attach the emby server log. Thanks.
django58 0 Posted January 19, 2020 Author Posted January 19, 2020 I tried to play some movies like "Alita" which is 5.1 but it didn't work. Logs : https://we.tl/t-VCekTpxccd
Luke 42216 Posted January 20, 2020 Posted January 20, 2020 What do you mean by didn't work? What exactly happened? What is the media info of the file?
django58 0 Posted January 20, 2020 Author Posted January 20, 2020 I mean that the movie plays as well but I don't get 5.1 sound through chromecast because of its audio codec (I want to read french version)
django58 0 Posted January 21, 2020 Author Posted January 21, 2020 (edited) I think I find a solution, actually emby (ffmep) transcode the movie from aac to ac3 (and don't transcode ac3 to aac)... Like Chromecast doesn't support ac3, how can I disallow this ? Edited January 21, 2020 by django58
Luke 42216 Posted January 26, 2020 Posted January 26, 2020 @@django58 can you please attach the log files to this posting? Thanks.
