ghostguy 6 Posted June 19, 2014 Posted June 19, 2014 Got the plug-in and set max audio levels. However some of the .mp3 the plugin pulls are VERY low in source volume and so when my normalization is set for -18 the loud ones are perfect but the ones that are quiet themes are barley audible or even non existent until i max out my Receiver volume, Thoughts?
yardameus 221 Posted June 21, 2014 Posted June 21, 2014 Maybe not the best for fidelity, but I'd just download MP3Gain and set the gain to the level of ones that you like. You should be able to do it as a batch. Quick and easy.
Chro 5 Posted June 21, 2020 Posted June 21, 2020 (edited) On 6/21/2014 at 7:15 PM, yardameus said: Maybe not the best for fidelity, but I'd just download MP3Gain and set the gain to the level of ones that you like. You should be able to do it as a batch. Quick and easy. Do you have a batch to easily adjust all mp3 themes in a folder including all subdirectories with MP3Grain? Edited June 25, 2020 by Chro
