Guest asrequested Posted January 14, 2020 Posted January 14, 2020 Is hardware transcoding actually happening?
pir8radio 1313 Posted January 14, 2020 Posted January 14, 2020 https://www.ebay.com/itm/1U-Supermicro-6-bay-Server-Mining-2-GPU-SLOT-1017GR-TF-Xeon-E5-2620-V2-64GB-Ram/133183361630?epid=141689379&hash=item1f0258d25e:g:m8QAAOSwAk5di6uo Then get one or two Quadro RTX 4000 GPU's and call it a day lol. I only have one P4000 in my server and it does decent... I have 3 GPU slots open.
BAlGaInTl 288 Posted January 14, 2020 Author Posted January 14, 2020 Is hardware transcoding actually happening? Sure seems like it. I'm not great at reading logs, but I'll attach a couple below. The dashboard says NVENC is being used. https://www.ebay.com/itm/1U-Supermicro-6-bay-Server-Mining-2-GPU-SLOT-1017GR-TF-Xeon-E5-2620-V2-64GB-Ram/133183361630?epid=141689379&hash=item1f0258d25e:g:m8QAAOSwAk5di6uo Then get one or two Quadro RTX 4000 GPU's and call it a day lol. I only have one P4000 in my server and it does decent... I have 3 GPU slots open. A 1070 Ti should be able to handle a single transcode without any issue I would think. Transcode01.txt Transcode02.txt
Happy2Play 9811 Posted January 14, 2020 Posted January 14, 2020 (edited) Sure seems like it. I'm not great at reading logs, but I'll attach a couple below. The dashboard says NVENC is being used. A 1070 Ti should be able to handle a single transcode without any issue I would think. And if you applied a reasonable or lower than the original 4K bitrate do you see a difference as you are converting 265 to 264 at almost 140Mb. This conversion between the two codecs doubles the bitrate, so if the device is set to max bitrate 140Mb and your HEVC media has a bitrate of 70Mb, you end up with a h264 of 140Mb. To me this chart would suggest what you are seeing. https://www.elpamsoft.com/?p=Plex-Hardware-Transcoding Edited January 14, 2020 by Happy2Play 1
pir8radio 1313 Posted January 14, 2020 Posted January 14, 2020 (edited) Sure seems like it. I'm not great at reading logs, but I'll attach a couple below. The dashboard says NVENC is being used. A 1070 Ti should be able to handle a single transcode without any issue I would think. but a 1070 wont do 10 or 12 bit, or HEVC. That's the issue i'm finding with my p4000 I need to get one of the RTX's It does decent with regular HD movies though... Keep your computer and go GPU :-) 10:47:43.346 frame= 5115 fps=729 q=25.0 size= 33239kB time=00:03:32.94 bitrate=1278.7kbits/s dup=1023 drop=0 throttle=off speed=23.9x Edited January 14, 2020 by pir8radio
BAlGaInTl 288 Posted January 14, 2020 Author Posted January 14, 2020 but a 1070 wont do 10 or 12 bit, or HEVC. That's the issue i'm finding with my p4000 I need to get one of the RTX's It does decent with regular HD movies though... Keep your computer and go GPU :-) 10:47:43.346 frame= 5115 fps=729 q=25.0 size= 33239kB time=00:03:32.94 bitrate=1278.7kbits/s dup=1023 drop=0 throttle=off speed=23.9 That probably explains it then. I think this files are 10 bit and/or HEVC.
pir8radio 1313 Posted January 14, 2020 Posted January 14, 2020 That probably explains it then. I think this files are 10 bit and/or HEVC. You know what. I might have been mistaken. Looks like it should actually. https://developer.nvidia.com/video-encode-decode-gpu-support-matrix Sent from my iPhone using Tapatalk 1
Happy2Play 9811 Posted January 14, 2020 Posted January 14, 2020 You know what. I might have been mistaken. Looks like it should actually. https://developer.nvidia.com/video-encode-decode-gpu-support-matrix Sent from my iPhone using Tapatalk Was just going to mention that.
Guest asrequested Posted January 14, 2020 Posted January 14, 2020 (edited) but a 1070 wont do 10 or 12 bit, or HEVC. That's the issue i'm finding with my p4000 I need to get one of the RTX's Yes it will. Most main stream HDR or 4k stuff is 4:2:0 Edited January 14, 2020 by Doofus
BAlGaInTl 288 Posted January 14, 2020 Author Posted January 14, 2020 Yes it will. Most main stream HDR or 4k stuff is 4:2:0 What does the 4:2:0 represent?
Guest asrequested Posted January 14, 2020 Posted January 14, 2020 What does the 4:2:0 represent? Chroma sub-sampling. 4:2:0 is standard, then 4:2:2 and 4:4:4 is the highest, when you can't use RGB10. https://www.rtings.com/tv/learn/chroma-subsampling 1
