JohnnyM 40 Posted June 19, 2014 Posted June 19, 2014 I noticed the Rotten Tomatoes rating information for the movie "Her" is displaying as 9%. This is consistent across all my movies. That value doesn't make sense to me. The critics rating for this movie is 94 and Audience Meter is 85. Is there an issue with this. Top left corner display attached. Johnny
JohnnyM 40 Posted June 20, 2014 Author Posted June 20, 2014 (edited) It shows 8.5%. The latest Rotten Tomato ratings are Tomatometer of 94% Average Rating of 8.5 out of 10 Audience Rating of 84% Average Rating of 4.1 out of 5 Which rating is it trying to expose? Looking at the XML I assume it is the Critics Rating of 8.5 out of 10 and therefore the only issue is the percent sign shouldn't be there. Johnny FLUP - I noticed the section in the web client giving the ratings and it shows 8.5% but it looks like it is directly from RottenTomatoes. (In their colors and format) Edited June 20, 2014 by JohnnyM
ebr 16306 Posted June 20, 2014 Posted June 20, 2014 Okay, then this is something with either the data coming from our source or the server. Is it the same on all movies or just some?
JohnnyM 40 Posted June 20, 2014 Author Posted June 20, 2014 It displays like that for all movies. I used GetItems to display the database and it shows a critics rating of 8.5 (No % sign). The WebClient shows 8.5% and WBC using Chocolate displays 9% (I Assume it is rounding and formatting with a %). I assume that a percent sign is added somewhere when is shouldn't be. Johnny
ebr 16306 Posted June 21, 2014 Posted June 21, 2014 No, that field was always filled with the tomato meter score - which is a % and all of my movies are displaying it properly. @@Luke, has something changed in the way these values are filled in? I am using CriticRating and it looks like the web client is too.
JohnnyM 40 Posted June 21, 2014 Author Posted June 21, 2014 I found the problem and it was on my side. There is nothing wrong with MB3 client. Fixing my side clears the problem and now it displays in all client like it should. Sorry about that. EBR have a great vacation Johnny M
