ilnegretto 0 Posted January 11, 2020 Posted January 11, 2020 (edited) hi, i recently moved to Emby from Plex and one thing that attracted me was the ability to add m3u links or file without the need of an additional software. so i signed up to premiere and it loaded the file perfectly. but when i play a channel, it lasts 30 seconds and it stops and i am not sure what is going on. when i use the same m3u file on vlc or any iptv player, it works perfect. searched through the forum and was adviced to tick something on auto loop but i cannot find that option. any help please? cheers Logs.txt Edited January 11, 2020 by ilnegretto
Luke 42244 Posted January 11, 2020 Posted January 11, 2020 Hi there, are you able to configure your provider for mpegts output? That may help with this.
ilnegretto 0 Posted January 11, 2020 Author Posted January 11, 2020 hi, not sure how to do that as i purchased from a provider and the other one is a free one online. is there anyway to fix this?
ilnegretto 0 Posted January 11, 2020 Author Posted January 11, 2020 Hi there, are you able to configure your provider for mpegts output? That may help with this. @@cayars hi, not sure how to do that as i purchased from a provider and the other one is a free one online. is there anyway to fix this?
Luke 42244 Posted January 11, 2020 Posted January 11, 2020 Your provider is sending back a 403 forbidden error: 17:37:23.378 [http @ 000002796222ab80] HTTP error 403 Forbidden 17:37:23.378 [hls @ 00000279618df100] Failed to reload playlist 0 Can you find out why from them?
