donati 1 Posted January 10, 2020 Posted January 10, 2020 I have payed for unlock using Google Play Store, paying with bankcard and walked through the unlock steps in the application, but the trial reminder keeps on appearing every time I start a video (on the home network). How can it be changed?
ebr 16338 Posted January 10, 2020 Posted January 10, 2020 Hi. Have you re-started the app since you unlocked it? Does it show as "registered" on the settings screen?
donati 1 Posted January 10, 2020 Author Posted January 10, 2020 Hello! Yes, I have restarted the app (and also the TV box). In the bottom right corner of the settings screen it says: Version 1.7.54g In trial. Expires 1.21.2020
ebr 16338 Posted January 10, 2020 Posted January 10, 2020 If you try to unlock again, is there a restore purchase button? Are you sure the unlock worked?
Solution donati 1 Posted January 10, 2020 Author Solution Posted January 10, 2020 There was a Restore Unlock button, I used it and the reminder disappeared. So it is OK now. Thank your for your help! 1
