Damian Andreu 0 Posted January 9, 2020 Posted January 9, 2020 No logro descargar la app en mi tv Samsung
Luke 42242 Posted January 10, 2020 Posted January 10, 2020 Hola por que no ¿Qué pasa cuando lo intentas?
Damian Andreu 0 Posted January 12, 2020 Author Posted January 12, 2020 Hola e intentado descargarla de la tienda y no aparece intente cambiar la region y nada, luego deascarge el punto zip
Damian Andreu 0 Posted January 12, 2020 Author Posted January 12, 2020 and when I prepare the usb the TV does not install it, as a result of the problem I tried to install it on a friend's tv the installa app but it only opens if I am online. The idea is to connect to my local server because in Cuba the internet is exceedingly expensive @@FrostByte
FrostByte 5453 Posted January 12, 2020 Posted January 12, 2020 What version are you installing from USB? I thought you had an Orsay TV?
