Luke 42246 Posted January 15, 2020 Posted January 15, 2020 Can you provide a new log example with the plugins i mentioned earlier all removed? Thanks.
bretswinney 22 Posted January 15, 2020 Author Posted January 15, 2020 Also is the C: drive on an SSD? Yes all drives are SSD Sent from my iPad using Tapatalk
bretswinney 22 Posted January 15, 2020 Author Posted January 15, 2020 Can you provide a new log example with the plugins i mentioned earlier all removed? Thanks. Here you go! embyserver.txt
Luke 42246 Posted January 15, 2020 Posted January 15, 2020 I notice you hadn't been around much lately. Is this a recent brand new installation of Emby Server, or did you update an old one?
bretswinney 22 Posted January 15, 2020 Author Posted January 15, 2020 I notice you hadn't been around much lately. Is this a recent brand new installation of Emby Server, or did you update an old one? This is the same one. Everything has been working lately so I haven’t been on the forums as much. Sent from my iPad using Tapatalk
Luke 42246 Posted January 15, 2020 Posted January 15, 2020 I still see the theme song plugins. Can you uninstall them and restart the server? While you're there, please uninstall all of these: Movie Theme Songs 1.6.6.4 Playback Reporting 1.6.8.1 Pushover Notifications 3.1.3.0 Theme Songs 1.6.6.4 These plugins create a lot of activity on your server. We need to rule out the possibility that this is having an impact.
bretswinney 22 Posted January 15, 2020 Author Posted January 15, 2020 I still see the theme song plugins. Can you uninstall them and restart the server? While you're there, please uninstall all of these: Movie Theme Songs 1.6.6.4 Playback Reporting 1.6.8.1 Pushover Notifications 3.1.3.0 Theme Songs 1.6.6.4 These plugins create a lot of activity on your server. We need to rule out the possibility that this is having an impact. But if it was the server why is it only having issues on the firetv app? Those plugins I have had from day 1 with no issues. Sent from my iPad using Tapatalk
Luke 42246 Posted January 15, 2020 Posted January 15, 2020 They're filling up the server log with activity. As they are not part of the core server, if it turns out that one of these is causing a performance impact then we'll be chasing our tails here looking for something that doesn't exist. Maybe the firetv app is giving up on requests a little sooner than the other apps, thus leading to the volley errors, but nonetheless, you have some slow response times in your server log that we should get to the bottom of.
bretswinney 22 Posted January 15, 2020 Author Posted January 15, 2020 They're filling up the server log with activity. As they are not part of the core server, if it turns out that one of these is causing a performance impact then we'll be chasing our tails here looking for something that doesn't exist. Maybe the firetv app is giving up on requests a little sooner than the other apps, thus leading to the volley errors, but nonetheless, you have some slow response times in your server log that we should get to the bottom of. Ok I will remove them so I can help solve the issue. They are removed. What next? Sent from my iPad using Tapatalk
Luke 42246 Posted January 15, 2020 Posted January 15, 2020 Please restart the server, get the problem to happen again if you can, then attach the emby server log. Thanks.
bretswinney 22 Posted January 15, 2020 Author Posted January 15, 2020 ok will do! Sent from my iPad using Tapatalk
Luke 42246 Posted January 15, 2020 Posted January 15, 2020 You can also try this and see if it helps: https://emby.media/community/index.php?/topic/75510-42032-vacuum-database-config-switch
bretswinney 22 Posted January 16, 2020 Author Posted January 16, 2020 You can also try this and see if it helps: https://emby.media/community/index.php?/topic/75510-42032-vacuum-database-config-switch Went from 1.2 GB library.dat to 600MB Hopefully this helps.
bretswinney 22 Posted February 5, 2020 Author Posted February 5, 2020 It has gotten better since the app update Sent from my iPad using Tapatalk
dicarlo_g 0 Posted June 26, 2020 Posted June 26, 2020 Hi I’m getting a volley error on my firestick when trying to login using connect and the pin on another device how do I fix please?
Luke 42246 Posted June 26, 2020 Posted June 26, 2020 1 hour ago, dicarlo_g said: Hi I’m getting a volley error on my firestick when trying to login using connect and the pin on another device how do I fix please? Hi there, please attach the emby server log. Thanks.
dicarlo_g 0 Posted June 26, 2020 Posted June 26, 2020 32 minutes ago, Luke said: Hi there, please attach the emby server log. Thanks. How do I get it I’ve just sent it on emby firestick app???
ebr 16338 Posted June 27, 2020 Posted June 27, 2020 Hi. "Volley" is just a generic term for "network" in this case. Are you sure your server is running and reachable?
