Skyobliwind 7 Posted March 20, 2020 Author Posted March 20, 2020 For me that doesn't seem to be the Problem, but I reasearched a little, installed a second instance of the plugin, also installed a freebsd jail and setup the newest beta in it. When installing the beta I noticed the downloadlink "https://github.com/MediaBrowser/Emby.Releases/releases/download/4.4.0.30/emby-server-freebsd11_4.4.0.30_amd64.txz" and when revieweing my errorlog I see -updatepackage emby-server-freebsd_{version}_amd64.txz at the end of the update command The small but BIG difference I noticed is the missing of the freebsd version in that Link if I manually try to resolve https://github.com/MediaBrowser/Emby.Releases/releases/download/4.2.1.0/emby-server-freebsd_4.2.1.0_amd64.txz in my Browser I also get Error 404 but if I add the FreeBSD Version 11 in the Link to https://github.com/MediaBrowser/Emby.Releases/releases/download/4.2.1.0/emby-server-freebsd11_4.2.1.0_amd64.txz it resolves perfectly good. Is it possible that you forgot to change the Update Link when you included FreeBSD12 support? I am rly sure changing this would fix the Problem for me. (But I think for security reasons I can't change the Updatelink myself ?) Regards
Luke 42239 Posted March 20, 2020 Posted March 20, 2020 For me that doesn't seem to be the Problem, but I reasearched a little, installed a second instance of the plugin, also installed a freebsd jail and setup the newest beta in it. When installing the beta I noticed the downloadlink "https://github.com/MediaBrowser/Emby.Releases/releases/download/4.4.0.30/emby-server-freebsd11_4.4.0.30_amd64.txz" and when revieweing my errorlog I see -updatepackage emby-server-freebsd_{version}_amd64.txz at the end of the update command The small but BIG difference I noticed is the missing of the freebsd version in that Link if I manually try to resolve https://github.com/MediaBrowser/Emby.Releases/releases/download/4.2.1.0/emby-server-freebsd_4.2.1.0_amd64.txz in my Browser I also get Error 404 but if I add the FreeBSD Version 11 in the Link to https://github.com/MediaBrowser/Emby.Releases/releases/download/4.2.1.0/emby-server-freebsd11_4.2.1.0_amd64.txz it resolves perfectly good. Is it possible that you forgot to change the Update Link when you included FreeBSD12 support? I am rly sure changing this would fix the Problem for me. (But I think for security reasons I can't change the Updatelink myself ?) Regards Hi, can you please attach the emby server log so that we can see an example of that? Thanks.
Luke 42239 Posted March 20, 2020 Posted March 20, 2020 For me that doesn't seem to be the Problem, but I reasearched a little, installed a second instance of the plugin, also installed a freebsd jail and setup the newest beta in it. When installing the beta I noticed the downloadlink "https://github.com/MediaBrowser/Emby.Releases/releases/download/4.4.0.30/emby-server-freebsd11_4.4.0.30_amd64.txz" and when revieweing my errorlog I see -updatepackage emby-server-freebsd_{version}_amd64.txz at the end of the update command The small but BIG difference I noticed is the missing of the freebsd version in that Link if I manually try to resolve https://github.com/MediaBrowser/Emby.Releases/releases/download/4.2.1.0/emby-server-freebsd_4.2.1.0_amd64.txz in my Browser I also get Error 404 but if I add the FreeBSD Version 11 in the Link to https://github.com/MediaBrowser/Emby.Releases/releases/download/4.2.1.0/emby-server-freebsd11_4.2.1.0_amd64.txz it resolves perfectly good. Is it possible that you forgot to change the Update Link when you included FreeBSD12 support? I am rly sure changing this would fix the Problem for me. (But I think for security reasons I can't change the Updatelink myself ?) Regards Ok reading through this again, the freebsd package urls have changed since 4.3 so that's the difference. Back during Emby Server 4.2 development was only had one freebsd package. Then during 4.3 we split it into two packages, one for each freebsd version. Does this answer your question?
Skyobliwind 7 Posted March 20, 2020 Author Posted March 20, 2020 Kind of. It confirms my guess, but how do I fix this? I have the newest available FreeNas plugin installed (4.2.10). Can I somehow manually change the link on which the server tries to search for updates? Or will the 4.3.10 Version release as FreeNAS Plugin in near future with the fix? I just want to stop the "Search for Plugin Updates failed" and "Search for Server Updates failed" messages ^^
Luke 42239 Posted March 20, 2020 Posted March 20, 2020 Or will the 4.3.10 Version release as FreeNAS Plugin in near future with the fix? We're hoping it will, although we'll be releasing 4.4 any day now.
Skyobliwind 7 Posted March 20, 2020 Author Posted March 20, 2020 (edited) I can also Post the whole Log, but the Interesting part will be: 20 19:14:47.779 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2020-03-20 19:14:47.779 Info TaskManager: StartupTrigger fired for task: Check for application updates 2020-03-20 19:14:47.780 Info TaskManager: Queueing task PluginUpdateTask 2020-03-20 19:14:47.780 Info TaskManager: Queueing task SystemUpdateTask 2020-03-20 19:14:47.782 Info TaskManager: Executing Check for application updates 2020-03-20 19:14:47.782 Info TaskManager: Executing Check for plugin updates 2020-03-20 19:14:47.786 Info HttpClient: HttpClientManager GET: https://www.mb3admin.com/admin/service/EmbyPackages.json 2020-03-20 19:14:47.842 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2020-03-20 19:14:47.851 Info TaskManager: ExecuteQueuedTasks 2020-03-20 19:14:50.834 Error HttpClient: Error NameResolutionFailure getting response from *** Error Report *** Version: 4.2.1.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz Operating system: Unix 11.3.6.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.10.1.57 (5.10.1.57 Tue Dec 10 07:40:49 UTC 2019) Runtime: file:///usr/local/lib/mono/4.5/mscorlib.dll Processor count: 12 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server/system System.Net.WebException: System.Net.WebException: Error: NameResolutionFailure at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00058] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <0e06830de9a44394a7e366951eabca52>:0 Source: System TargetSite: System.Net.WebResponse EndGetResponse(System.IAsyncResult) As you can see in the End of "Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd_{version}_amd64.txz"it says emby-server-freebsd and not emby-server-freebsd11 Same for the Server and for the Plugin Updates Edited March 20, 2020 by Skyobliwind
Skyobliwind 7 Posted March 20, 2020 Author Posted March 20, 2020 (edited) And that seems to cause: Edited March 20, 2020 by Skyobliwind
Luke 42239 Posted March 20, 2020 Posted March 20, 2020 Generally this is caused by something blocking Emby Server from sending the requests, such as a firewall, security software, or VPN. Can you look into this?
Skyobliwind 7 Posted March 20, 2020 Author Posted March 20, 2020 Nah, we turn around I think ^^ I already looked Up everything for quite some time now. Everything works BUT the Update link inside the automatically created Freenas Plugin Jail seems to bee broken. Just try to manually type in your Browser --github.com/MediaBrowser/Emby.Releases/releases/download/4.2.1.0/emby-server-freebsd_4.2.1.0_amd64.txz-- (THAT is the Link my emby plugin looks for updates) and you will get Error 404 The actually WORKING link is --github.com/MediaBrowser/Emby.Releases/releases/download/4.2.1.0/emby-server-freebsd11_4.2.1.0_amd64.txz-- The link that my plugin uses misses the 11 in it so it can't find anything there, because you seem to have changed the link AFTER the plugin was released and it still uses the old Link.
Skyobliwind 7 Posted March 20, 2020 Author Posted March 20, 2020 Do you Plan to release the 4.3.10 or directly go on 4.4 for the FreeNas Plugin?
Luke 42239 Posted March 20, 2020 Posted March 20, 2020 We don't actually release the FreeNAS plugin ourselves. We submit to FreeBSD ports, and FreeNAS picks it up from there.
Skyobliwind 7 Posted March 20, 2020 Author Posted March 20, 2020 So there is no way for me to fix the Link somewhere in the Update config? Any File on the System or something? In the Log I can see the command that is run, but not from where it is triggered.
Luke 42239 Posted March 20, 2020 Posted March 20, 2020 There is no automatic update for FreeBSD. The only thing that does is notify you when an update is available, so that notification is all you're missing out on. Well that and plugin updates.
makarai 109 Posted March 21, 2020 Posted March 21, 2020 @@Skyobliwind did you upgrade toi 11.3 version of freenas ? If so, you can choose the community plugin repository and install 4.3.1.0 of emby.
MRobi 161 Posted March 21, 2020 Posted March 21, 2020 If you're decently fluent with FreeNAS you could also manually install 4.3.1.0 from shell using the beta instructions with the 4.3.1.0 package
Skyobliwind 7 Posted April 19, 2020 Author Posted April 19, 2020 Im using the community plugin version now and the error is gone. 2
