neodago 3 Posted January 5, 2020 Posted January 5, 2020 I have a little issue with this app: when i play a video, after some minutes, it "freezes" for 30 seconds (more or less) and then the playback resumes normally. No matter if the video is 4K or 1080p, h264 or h265, every video freezes during play and no commands are received until it resumes play. Usually it happends only one time, but some times it happends more then one time. It's very annoying. The version of the app is 1.0.20 and runs on a LG OLED55C9PLA (WebOs 4.70.05). The server is version 4.3.0.30 running on a QNAP-TS-453Be NAS. With the android app or if I play the same files with kodi I have no problems at all. P.S. I am updating the server to version 4.3.1, but I don't think that this fixes the problem.
feeeeeef 0 Posted January 5, 2020 Posted January 5, 2020 I have the same problem, the same APP version, and the same model of LG TV. The TV is blank and you can only restart the TV. ops ~~
Luke 42237 Posted January 5, 2020 Posted January 5, 2020 HI, most likely the bitrate is too high for the device and network connection. Try lowering the bitrate in the app using in the in-app quality setting under playback settings. Please see if this helps. Thanks. @@SamES
SamES 1084 Posted January 6, 2020 Posted January 6, 2020 Are you using a wired or wireless network connection?
neodago 3 Posted January 6, 2020 Author Posted January 6, 2020 Are you using a wired or wireless network connection? Wired connection. Yesterday I saw a movie (4K HDR, very hight bitrare) and all played flawlessy. No freezes. Meanwhile I updated the server, the only change I made.
Tomas1987 1 Posted January 6, 2020 Posted January 6, 2020 (edited) Did Y turbiny off sub? Most of the internal movie subtitles forces transcoding. Thats why y having freezes. You should use extrenal .srt sub fotmat About network interfaces, my lg b7 have wired 100mb ethernet interfaces, that is not enought for 4k format. So I use wireless connection in 802.11ac anD everthing worka flawless. Edited January 6, 2020 by Tomas1987 1
