IRO 0 Posted January 5, 2020 Posted January 5, 2020 Hi, I have problems with subtitles on older webOS 2 tv sets. External srt is diplayed for a second then disappears. Subtitles embedded in the mkv file cannot be chosen, the first is displayed regardless of settings. Any other client I tried works fine, including newer LG tv sets, Android phones, a Samsung TV and several web browsers. (Screenplay application can't display subtitles either, so I think the problem must be webOS version related) I restarted the emby server from the web interface, then started a movie with an external subtitle. The subtitle displayed for a second, then disappeared. Subtitle size and colour settings were not what I set up previously in user preferences. The client I started the movie on: LG 43UF7787-ZA, application version Emby Theater 1.0.20, software version 04.05.85, webOS version 2.2.1-2147 (beehive-biscayne) My Emby server version is 4.3.1.0, it's running on a Synology DS215+ The user I tried to play the file with is named IRO. The movie is a H264 mkv with AC3 audio. Full details from the movie page are attached. According to the stats on the client interface and Emby dashboard the movie were direct played. I can't see new ffmpeg log files generated on the server if I start the movie on the TV, nor on my Android phone, so can't post them. (If I play from a web browser ffmpeg-directstream files are indeed created) I attach the embyserver and hardware-detection logs. If it's any help, the oldest LG set which works fine among the ones I tried is a 55LF652V-ZA, software version 04.06.30, webOS version 2.2.3-169 (beehive-biscayne). It's a slightly newer webOS but still version 2. embyserver.txt hardware_detection-63713812855.txt Once.Upon.A.Time.S01E01.Pilot.720p.WEB-DL.DD5.1.H.264-ECI.srt
SamES 1084 Posted January 6, 2020 Posted January 6, 2020 I have problems with subtitles on older webOS 2 tv sets. External srt is diplayed for a second then disappears. Subtitles embedded in the mkv file cannot be chosen, the first is displayed regardless of settings. Any other client I tried works fine, including newer LG tv sets, Android phones, a Samsung TV and several web browsers. (Screenplay application can't display subtitles either, so I think the problem must be webOS version related) Hi, thanks for raising this issue. This is a known limitation on older webOS models and an issue we are still working on resolving. Thanks
mx5gr 1 Posted January 7, 2020 Posted January 7, 2020 Hello,@@SamES I have similar issues with subtitles with a LG TV set as @@IRO describes under WebOS 1.4.0.LG 55UC970V-ZA, application version Emby Theater 1.0.20, firmware 05.05.90, webOS version 1.4.0-2337 (afro-ashley)My Emby server version is 4.3.1.0, it's running on a Raspberry Pi 4B 4GB under Rasbian. The user I tried to play the file with is named socrates.The TV series episode is a H264 mkv with AC3 audio. Full details (mediainfo) from the TV episode are attached.According to the stats on the client interface and Emby dashboard the TV episode was played through HTTP with no transcoding.I hope that the webOS 2.0 workaround (if a resolution is found) applies in 1.4.0. embyserver.txt hardware_detection.txt mediainfo.txt
SamES 1084 Posted January 7, 2020 Posted January 7, 2020 I hope that the webOS 2.0 workaround (if a resolution is found) applies in 1.4.0. Yes, that is the plan
CassianoG 0 Posted January 12, 2020 Posted January 12, 2020 Hi, thanks for raising this issue. This is a known limitation on older webOS models and an issue we are still working on resolving. Thanks Well... I've been having exactly the same symptoms as the openning post, but my TV is running WebOs 4.05.85.
SamES 1084 Posted January 13, 2020 Posted January 13, 2020 Well... I've been having exactly the same symptoms as the openning post, but my TV is running WebOs 4.05.85. That sounds like a firmware version, not the webOS version. I think this is webOS 2.0 firmware What is the model number of your TV? To check the webOS version, in LG Smart TV, go to Settings > Quick Settings > General > About this TV > webOS TV Version
CassianoG 0 Posted January 13, 2020 Posted January 13, 2020 That sounds like a firmware version, not the webOS version. I think this is webOS 2.0 firmware What is the model number of your TV? To check the webOS version, in LG Smart TV, go to Settings > Quick Settings > General > About this TV > webOS TV Version Hello @@SamES, you are completely right. Now I found it: Model: 49UF8500-SC WebOS version: 2.2.1-2147 (beehive-biscayne)
SamES 1084 Posted January 13, 2020 Posted January 13, 2020 Hello SamES, you are completely right. Now I found it: Model: 49UF8500-SC WebOS version: 2.2.1-2147 (beehive-biscayne) No problem, thanks for the update. Hopefully we can resolve this issue soon.
SamES 1084 Posted May 8, 2020 Posted May 8, 2020 I have the same issue. Any update on it? Sorry, not yet
Avesi 0 Posted May 26, 2020 Posted May 26, 2020 (edited) Same problem here, Lg web os: WebOS version: 2.2.3-169 (beehive-biscayne). TV model: 42LF652V-ZA, Lg theater 1.0.24 External subtitles for example in SRT format diapering after second, internal subtitles works fine. Edited May 26, 2020 by Avesi
IRO 0 Posted June 4, 2020 Author Posted June 4, 2020 I've just noticed that some of my movies have working external subtitles It looks like the ones with the Xvid codec shows the subtitles. Haven't done any extensive testing though, and I have only a couple of them. As I've just upgraded to 4.4.3.0 I must ask, did You do anything related to this? I didn't see anything in the changelog, and the LG app is still the same. There is a chance, that I didn't notice it working with Xvid, because I said I have only a few movies with this codec.
Luke 42237 Posted June 4, 2020 Posted June 4, 2020 No, this will require a coordinated workaround in both the server and the app.
crazyquark 2 Posted November 15, 2020 Posted November 15, 2020 (edited) For me it works as follows: SRT subtitles work always but .sub/subrip subtitles have like a sort of delay, it takes minutes before they start showing up and then it works for that file until the end. Some sort of buffering, matching, no idea? My WebOS software version is 5.20.02 on an LG OLED55C8PLA. My emby server is 4.6.0.5 beta(just switched to beta to see if it works better but I can switch back to stable). All other clients(browser, iOS, Infuse...) work fine with subtitles. Edited November 15, 2020 by crazyquark
Luke 42237 Posted November 15, 2020 Posted November 15, 2020 4 hours ago, crazyquark said: For me it works as follows: SRT subtitles work always but .sub/subrip subtitles have like a sort of delay, it takes minutes before they start showing up and then it works for that file until the end. Some sort of buffering, matching, no idea? My WebOS software version is 5.20.02 on an LG OLED55C8PLA. My emby server is 4.6.0.5 beta(just switched to beta to see if it works better but I can switch back to stable). All other clients(browser, iOS, Infuse...) work fine with subtitles. Hi there @crazyquark, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks ! 1
