Bigmack3000 108 Posted January 4, 2020 Posted January 4, 2020 I'm trying to Connect Kurosawa's Dreams through the metadata links: Those are the correct numbers as listed on those sites. However, after refreshing the metadata, Emby keeps loading this instead: The correct numbers are still listed in the metadata. It's just bringing up all of the wrong information. Any suggestions?
Bigmack3000 108 Posted January 5, 2020 Author Posted January 5, 2020 the Identify feature looks pretty identical to fixing the metadata, but I tried it, and the result was: This is weird because I'm copy and pasting directly from the imdb and themoviedb pages:
Bigmack3000 108 Posted January 5, 2020 Author Posted January 5, 2020 The Name, the year, and the two site numbers listed above. Must be just be some really random data error somewhere. I used only Imdb and it's connecting fine now.
Luke 42216 Posted January 5, 2020 Posted January 5, 2020 My guess, you customized your metadata settings for your movie library and now you're paying the price for that. Remember that both the metadata refresh and the Identify dialog incorporate your metadata settings for that library. With the server on default settings, it works perfectly and i get the Dreams title that you mentioned above. If you can provide a server log then I can verify this for you. Thanks.
Bigmack3000 108 Posted January 5, 2020 Author Posted January 5, 2020 I'm not sure what customizing I would've done unless it was by accident. The only time I touch the metadata for individual films is when it connects to the wrong film. Which log would you need?
Happy2Play 9806 Posted January 5, 2020 Posted January 5, 2020 (edited) https://www.themoviedb.org/tv/74864-akira-kurosawa-s-dreams?language=en-US vs https://www.themoviedb.org/movie/74864-watch-out?language=en-US Well TMDB list it as TV not Movie so you can not use that id as they are not compatible with Movie Content Types. I get a proper return from OMDB with IMDB id. Edited January 5, 2020 by Happy2Play
Bigmack3000 108 Posted January 5, 2020 Author Posted January 5, 2020 Oh wow. Didn't even notice that. This is not a tv show, so there's the error. Seems someone separated each chapter into an episode? Wait, so now I took tv out of the web address, and low and behold "Watch Out" popped out as a match. Themoviedb reuses it's ID's?
Happy2Play 9806 Posted January 5, 2020 Posted January 5, 2020 Oh wow. Didn't even notice that. This is not a tv show, so there's the error. Seems someone separated each chapter into an episode? Wait, so now I took tv out of the web address, and low and behold "Watch Out" popped out as a match. Themoviedb reuses it's ID's? Yes ids are reuse in movies and tv on TMDB do to their separation by type.
ebr 16313 Posted January 5, 2020 Posted January 5, 2020 Is this not the issue with the longer IMDb ID?
Happy2Play 9806 Posted January 5, 2020 Posted January 5, 2020 (edited) Is this not the issue with the longer IMDb ID? A /tv vs /movie query issue as shown in post 9 with id "74864", but the item does not have a IMDB id on TMDB either. Edited January 5, 2020 by Happy2Play 1
