msenjur 0 Posted January 4, 2020 Posted January 4, 2020 it doesnt matter if i cast from samsung or huawei device. volume is always at max. in then if i want to lower the volume, volume control button works weird. it isnt responsive as it should be. so, where can set default playback volume in app? im casting on samsung tv over chromecast.
ebr 16337 Posted January 4, 2020 Posted January 4, 2020 Hi. You are casting from the Android mobile app?
msenjur 0 Posted January 4, 2020 Author Posted January 4, 2020 hello! yes, im casting from mobile app...
msenjur 0 Posted January 6, 2020 Author Posted January 6, 2020 on my devices. phone or tab... if i try to lower the volume, i press multiple times, and than it just jump to mute, then i have to raise volume... and indicator of volume in app on tv and indicator on device is not showing the same value...
Luke 42244 Posted January 6, 2020 Posted January 6, 2020 Are you using an audio receiver, or is Chromecast hooked up to the TV directly?
