luckielukz 0 Posted January 3, 2020 Posted January 3, 2020 I already use Emby Server for Windows. I have tried all methods even uninstall emby and reinstall. but still google drive can't be used, even though the emby sync folder has appeared on my drive. Is there something wrong with what I'm working on? The sync menu does not appear at all
vladz0r 1 Posted January 3, 2020 Posted January 3, 2020 Having the same issue here. I use rclone to mount my gdrive. I'm almost ready to push the button and buy an emby pass since Plex can't do original quality downloads without conversion. The speed is kinda not as good on Emby for my 4G, though.
Luke 42216 Posted January 4, 2020 Posted January 4, 2020 Sync is now called "Download To...". Try using that menu and you should see google drive under there.
vladz0r 1 Posted January 5, 2020 Posted January 5, 2020 I think I was mixing this up and thinking this had to do with rclone, ignore my previous post.
Luke 42216 Posted January 5, 2020 Posted January 5, 2020 OK so that just leaves @@luckielukz. Has my response answered your question?
