Pilaf 0 Posted January 3, 2020 Posted January 3, 2020 Hi there I'm new here and French so excuse me for my english and for my question if it's not the right place Im using 4.3.0.21 beta version of the emby server on a QNAP TS-451+ HTTPS only with a lets encrypt certificate (renewed by script and transform to the emby pfx format, very proud of it hehe =) Im having issues with audio format (my freebox dont read DTS so im trying to add only AC3 vids now). With AC3 (or E-AC3?), its ok on my freebox, ok on my phones but i have no sound on a macos catalina, playing trough the webapp (no desktop application for mac right ?). Same with MP2 codec. Here is the audio description of a file with no sound on my mac with AC3 : Player: Web Video Player Play method: DirectPlay Protocol: https Stream type: Video Video Info Video resolution: 1280x720 Original Media Info Container: mkv Bitrate: 2.1 Mbps Video codec: H264 High Video bitrate: 2.1 Mbps Video framerate: 25 fps Audio codec: AC3 Audio bitrate: 384 kbps Audio channels: 6 Audio sample rate: 48000 Hz Here is the audio description of a file with no sound on my mac with MP2 : Player: Web Video Player Play method: DirectPlay Protocol: https Stream type: Video Video Info Video resolution: 1280x720 Original Media Info Container: mkv Bitrate: 2.0 Mbps Video codec: H264 High Video bitrate: 2.0 Mbps Video framerate: 25 fps Audio codec: MP2 Audio bitrate: 256 kbps Audio channels: 2 Audio sample rate: 48000 Hz Seems ok with AAC codec. Is this normal ? Can you help me ? Thanks in advance.
Luke 42239 Posted January 3, 2020 Posted January 3, 2020 Hi there, please update to Emby Server 4.3.1 and it should transcode the MP2 so that it will work. Thanks.
Pilaf 0 Posted January 3, 2020 Author Posted January 3, 2020 Hey thanks for your quick response ! I want the less transcoding possible to limit cpu usage, transcoding mp2 will increase much cpu usage ?
Luke 42239 Posted January 3, 2020 Posted January 3, 2020 Not much cpu usage, but if you want to avoid it, you'll need to convert the file to use aac audio or mp3. Our media conversion feature can help you do this.
