Bert 49 Posted August 23, 2014 Posted August 23, 2014 My tablet and chromecast are on WORKwifi my server is at home.
Tranquil 95 Posted August 26, 2014 Posted August 26, 2014 @Bert: Use the same external address within the app. I know your proble, I had the same. If you use a dyndns service, use this also for internal connection. Please make sure all required ports are forwarded on your router.
Bert 49 Posted August 26, 2014 Posted August 26, 2014 Since, as stated previously, I am not on my home network I have been using the external address. As far as I know the tablet itself wouldn't even work any other way. I forward 8096, is there something else I should forward?
Daimon 6 Posted August 26, 2014 Posted August 26, 2014 Have you tried setting your external ip in the internal field in the app? It looks the app uses the internal ip when sending the url to the chromecast even if you are connected to the external address. 1
Tranquil 95 Posted August 26, 2014 Posted August 26, 2014 Daimon is right. That is what the will do for sure atm.
Bert 49 Posted August 28, 2014 Posted August 28, 2014 Daimon was right, success! Thanks for the help!
