al15 0 Posted January 2, 2020 Posted January 2, 2020 Hallo, habe libreelec 9.2.0 mit Emyb addon 4.014a installiert und auf meinem Windows Server die letzte Emby 4.4.0.4 - seit kurzem habe ich aber probleme das die wiedergabe beim schauen von Filmen hängt daher habe ich mal debug logging eingeschalten und sehe da diese Fehler (dauernd) 2020-01-02 19:16:01.317 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: loading setting definitions 2020-01-02 19:16:01.317 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: trying to load setting definitions from old format... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: loading setting values 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (LastIncrementalSync) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting LastIncrementalSync. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (MinimumSetup) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting MinimumSetup. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (SyncInstallRunDone) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting SyncInstallRunDone. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (appliedPatch) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting appliedPatch. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (distroDetected) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting distroDetected. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (groupedSets) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting groupedSets. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (lowPowered) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting lowPowered. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (platformDetected) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting platformDetected. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (useWebServer) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting useWebServer. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (webServerPass) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting webServerPass. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (webServerPort) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting webServerPort. Creating a setting on-the-fly... 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CSettingsManager: requested setting (webServerUser) was not found. 2020-01-02 19:16:01.318 T:140553727497984 DEBUG: CAddonSettings[plugin.video.emby]: failed to find definition for setting webServerUser. Creating a setting on-the-fly... Habe das addion schon komplett gelöscht und neuinstalliert an den Einträgen ändert sich aber nichts - weis jemand an was das liegen könnte? DANKE lg AL
sualfred 677 Posted January 2, 2020 Posted January 2, 2020 (edited) Bitte ein volles, normales Log hochladen. Snippets reichen nicht. Edit: Und auch bitte einmal das Addon aus dem Beta Repo updaten. Wir sind schon bei 4.1.19 als Beta und bei 4.1.12 als stable. Edited January 2, 2020 by sualfred 1
al15 0 Posted January 4, 2020 Author Posted January 4, 2020 Hallo - werd gleich mal updaten scheinbar hat er das update nicht gefunden werd mal via zip updaten... Melde mich dann DANKE lg AL
sualfred 677 Posted January 4, 2020 Posted January 4, 2020 Prüf auch bitte ob du die aktuelle Repo Version installiert hast. Im Sommer/Herbst haben wir die Repo Struktur umgestellt. Normalerweise hätte Kodi das selber updaten sollen. http://kodi.emby.media/
